When the key is turned i get a clicking sound form the engine and the head light are dim
Low battery
Try this procedure:
Check the battery like this:
Turn on the headlights, then try to start the car.
If the headlights do not dim or go out, then the battery is likely ok.
Check that the battery cable plus post, goes to the starter, Minus post to a good ground, like the engine.
If wiring is ok, then look at the starter solenoid for a good connection, and proper voltage at the starter.
Problem is most likely the Solenoid's bendix gear or starting relay, Have someone bang on the starter while you try to start the car. This usually works by dislodging the bendix gear..
Hope this helps.
Take the starter off for testing. If the lights were normally bright, and went dim when key was in cranking position, it means the start circuit is working-battery power is going to the starter, but it won't do anything. The starter motor is probably bad.
Good luck.
SOURCE: honda crv engine light
I would go to your local Honda dealership and tell them the engine light came on. They will hook it up to a special computer and they will be able to tell you why the engine light came on and what's wrong with the car. Not sure what the cost will be to get it checked out. If you don't have the money for that right now.
SOURCE: MY 2007 HONDA CRV CAR RADIO LOCKED AND IS ASKING FOR CODE
inside glove box there should be a sticker with the radio serial number and code. if that has been removed then you could try the honda owners site. you'll need the vin # and some other info
I was able to get the code recently for my 2010 CR-V
SOURCE: 2005 Honda CRV won't start
if the clicking sound is coming from the engine compartment, it is the starter solenoid. let her try it a couple of times. sometimes it would connect and start the car. then she can bring it home.
tnx 4 using fixya,
drcool
SOURCE: Honda CRV 2007 dim headlights
add some driving lights or re aim your high beams lower so you can use them all the time.
SOURCE: Honda 97 crv engine turns off while driving, and hard to
manual 96 honda accord shuts off after starting. Unable to give the engine gas
