Washing Machines Logo
David Posted on Jul 14, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My simpson esprit 450 washes dirt/sand into the tub - how can I clean the
I'm guessing someone washed something full of sand because after each wash there is lots of bits of sand and dirt through everything. I took off the agitator trying to get the "drum" so I could clean it out, but that is not where you access it. Any ideas how to get access to the drum that fills up with water so I can clean it out?
luisa_sgro
Level 3:
  • Washing Mach... Master 713 Answers
  • Posted on Jul 15, 2012
luisa_sgro
Level 3:
Answers
713
Questions
0
Helped
239515
Points
1926
Hi just read your posting.The only way you can assess the tank is to remove the inner bowl.This is quite difficult.I can help you with removing the inner bowl but I think the easiest way is to fill the machine on a High water level and when it stops filling and starts to agitate pause the machine and advance the cycle to spin and let the pump drain out the sandy water.Give this a try the reply back on how you got on.
5 Related Answers
Anthony Abbott
  • 136 Answers
  • Posted on May 29, 2009
SOURCE: My washing machine is leaving powder/liquid all over the clothes
you're using too much detergent
Anonymous
  • Posted on May 04, 2010
SOURCE: Simpson Esprit 450 Washing machine
I'm having the same issue, did you get any resolution?
Anonymous
  • Posted on Aug 10, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
luisa_sgro
  • 713 Answers
  • Posted on May 24, 2011
SOURCE: simpson esprit 450 washing machine timer not
Hi just read your posting.Now just a couple of questions.What water temp have you set the machine for,Is it cold,cold or another setting.Have you got the cold hose going from the cold tap to the cold water valve on the machine with is marked with a C and the same for the hot which is marked H.Please reply with answers to all the questions and I am sure I can help you with this fault.Looking forward to your reply.
Anonymous
  • 1998 Answers
  • Posted on Jun 12, 2011
SOURCE: Hi i have a simpson esprit and I can't stop the
If the water continuously keeps filling the tub of the washer this would be due to either you have a bad pressure switch or the hose that is connected to the pressure switch that goes down the side of the unit and connects to the tub has either comes off its connection point or has sediment or debris inside the hose itself which would cause the same issue here is also a basic video of how the pressure switch test is done click this link http://www.youtube.com/watch?v=HZZ2bDMspj8 if you have any further questions message me back and please remember to rank this opinion when our chat has fully concluded it allows me to continue helping others in similar situations in the future. Thanks again for using Fixya
Rick
Simpson esprit 450 washing machine. Sometimes it will do the final spin and othertimes not spin at all. The machine is 11yrs old.
Probably a timer problem but you need fault finding knowledge and a test meter to find the fault. There are a few other reasons to not spin. You haven't said if you have a test meter or fault finding skills.
Simpson esprit 450 washing machine The machine only adjatates in one direction
try another capacitor,located under main control panel, easy to replace,or the tip of the clutch pawl has broken off, this located on the end of the brake arm
Simpson washing machine will not fill with water. Epsrite 750. Hoses are fine, water pressure is fine. Just a dribble goes into the tub
Most hoses have a filter/strainer at the faucet end. This can get clogged. Remove from water source, check and clean.
faulty control board or timer
Water drain out immediately while filling the washing machine
you should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Simpson espirit 750 manual required can't change water level
Hello
Try these links to download the manual to your machine.
laundry.manualsonline.com/ex/product/.../m/simpson/d/.../22S750M
http://www.dataentryjobs.us/67948.html
trd-techconnect.net/User's%20guide,%20Instructions%20book
www.search-document.com/pdf/.../simpson-esprit-washingmachine
www.sign.ac.uk/pdf/sign97.pdf
3helpful
Simpson esprit 450 washing machine top loader
Top Washing Machines Experts
john h
