mods, it's a modifcations post. rare... here...
first off ,you did willingly break your car, why do that.?
and if car has issues later on the road, the mechanic will hate you for this.
he may in fact say, sorry buddy, take it to a custom shop....
(it is your car, but...... think about the future... and resale, id never
buy your hacked up car. me and millions like me.... )
but if so inclined, you take the factory drawings (FSM)
then red ink the mods.
then post it and i can answer with 100 % accuracy,
your lights on off post makes no senses
my guess is the park circuits are crosswired.
one big failing with LED modders. is the lack of understanging
that some components on the car are sensitive to current'.
or have normal leakages. bad for LEDs.
that would just hate LEDs.
and the one in this car is not SPECIFIED.
how many LEDs did you install and where, we got the turns stated.
are you LEDing the Park circuit too ? aka TAIL?
the hazard module in the column, is an electronic type module.
the jeep lights are oddly wired,
see the schematic below. see how the
1 lamp element us used for many functions?
ignore red balls, they are for brake failure only.
http://www.fixkick.com/look/odds-ends/jeep/95wrang.jpg
the blk-yell is the park feed. if the park switch leaks, the LED will glow easy. . keep in mind the switches being old and the grease starts to conduct (metal wear ) and at 0.010 amps the LED glows.
so fails. a 1 amp factory lamp draws 100 times more, so will no glow.
see? the only solution to that is a new combo or removing all the nasty old grease in the switch. (im a certified tech, retired and see it all)
now look at the tan wire. ( the brake/ turns are shared , on jeeps)
see the TAN?
see how the markers are wired to brake turns? feed>?
odd , huh?
for sure the LED usage will in fact find all current leakages in the whole circuit. just 10/1000th of an ampere and it glows,
i hope this helps, but do post the mods to my drawing.
and we can in fact find any failure. any leakage,
sure can. with and accurate drawing and a meter.
good luck.
