Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Anonymous Posted on Jul 14, 2012
My liftmaster seems to shut down when the outside temperature is to hot but it will turn back on when the garage temp is cooled down
  • Anonymous Jul 17, 2012
    it s like there is no power to the unit even though the sensor lights are on
    Then when the garage temperature cools down the unit come alive again and works fine
  • Anonymous Jul 18, 2012
    can you help?
Anonymous
Level 3:
President:
  • Master 3,197 Answers
  • Posted on Jul 16, 2012
Anonymous
Master
Level 3:
President:
Answers
3197
Questions
Helped
1457997
Points
8183
You say it seems to shut down. What actually does it do?
    its like there is no power to the unit even though the sensor lights are on. Then when the garage temperature cools down the unit comes alive again and works fine.
    Thanks for your reply Don
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jul 10, 2008
SOURCE: Liftmaster Garage Door Opener Problems...
The problem lies in the RPM sensor, most likely due to the interrupter cup assembly. The interrupter cup assembly is the black cap that runs through the RPM sensor. You may have forgotten to re-attach this piece or it is probably moving too far out when the garage sets in motion. To fix this, remove the cup assembly, unscrew the two screws on the top metal piece with a 1/8 allen wrench, push the metal piece as far in as possible and put the screws back on. This will give more room for the cup assembly to spin and be read by the RPM sensor. Hope this helps!
SeanAA
  • Posted on Jul 25, 2008
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Anonymous
  • 476 Answers
  • Posted on Aug 02, 2008
SOURCE: Liftmaster garage door opens and
is there something jamming it travel of the door?
or does the travel distance of the door need adjusting?
How many remotes do you have?
do their batteries need a changing?
even with the power disconnected you should be able to close the door,
do this and check from there,
any of the switchs sticking down?
If it persists then call some one to fix it,
They are normally bullettproof if installed properly and servicing and lubracating them seems to be a good idea too,
some buildings shrink and contract more than others
Yours seem to be normal movement of the building structure.
winter and summer situtation.
check the adjustments on the travel,
Let me know the outcome thanks .....
Anonymous
  • 3197 Answers
  • Posted on May 18, 2009
SOURCE: Garage door shuts down, need to press reset to get it to work
On the side of the opener you will find the down limit control. Turn this a bit in the opposite direction of the arrow printed on the cover. You will probably have to tweak it a bit to get it just right.
Anonymous
  • 3197 Answers
  • Posted on May 19, 2010
SOURCE: Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
PTAC stops running after a short time
Sounds like a voltage or amp draw issue. So how about if you only try to run the blower??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
McQuay PTAC stops working after short time
Sounds like you need a new control board with thermistors. you probably have a relay that is getting hot and quitting.
2helpful
I have a LiftMaster 1/2 HP garage door. From the closed position, when I open it, it slides up, then stops halfway. When I disconnect the door (to manual open/close) and operate the door opener, the...
Sounds like it might be a resistance (weight) issue. It's not the temperature since mine opens when my garage temperature is 15-20 degrees (outside temp even lower).
Whenever the temperature drops below approx 40 degrees the door only opens anywhere from 12" to 3ft. The door works fine when the outside temp is above 40. When I unhook the door from the opener it moves...
Make sure there is no grease in the rails. This can congeal and cause this problem. The 'up force' control is on the panel where all those white wires go. You can try increasing this also.
1helpful
Cooling fans in op until engine is shut down . At idle, in traffic, temp gets high, hen wmoving, temp goes back to normal. When I shut down the engine the fans start to run as they are supposed to when the...
Check out clarks-garage.com he has a complete troubleshooting guide for your cooling system along with a schematic. In short, check the low speed resistor on the firewall. Should be around one ohm.
1helpful
Fluctuating engine temp a/c sends out cold air intermittently
Here's the thing. The ECU will shut down AC if the engine temperature is too hot. If the coolant temperature sensor is malfunctioning (lying to the ECU) telling it that the temperature is hotter than it actually is, the computer will turn the AC OFF.
4helpful
Air conditioner compressor keeps shutting down
This is due to thermal overload,Which can be caused by low oil in the compressor,the fan has stopped running on the unit outside,Dirty coils,or just a worn out compressor.Although this is thermal overload,It has nothing to do with outside temperature,But rather the internal temperature of the compressor itself.
7helpful
2answers
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
