Temperature flucuates from 0 to 32 F or better while the manual temp is set at #5 (a la factory) with 1(least cold) to 9(coldest) range, the unit is about 1 1/2 years old, frost surrounds fan and it is a frost free unit. also , there is ice formed on the back inside wall beginning in the uppermost left hand corner and settling down on the bootm where there is at least a sheet of ice over and inch thick covering the entire bottm platform
SOURCE: Ice forms on copper pipe under freezer off compressor
it sound like your unit has a bad sensor on it or a leak. you should never have to add refrigerant to a unit unless theres a leak then it has to be repaired firdt the recharged.
SOURCE: upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
SOURCE: Freezer Compressor Motor turns on and right back off
please check the following list,
1) check wheather the service wire is in good condition or not.
2) thermostart might have been off.
3) turn the refrigerator backword and see if is there any wire is disconnected/cut.
4) try changing the plug of the refrigerator.
if your problem is not fixed than please contact the service engineer. i'm sure that your stater had been blown.................. have a nice day:-)
SOURCE: Upright Frigidaire freezer with warning buzzer on constantly
If your'e positive the temp is ok then your freezer cold control may be bad. Slowly turn it toward off. If the compressor doesn't cut off before it gets to off, the control is probably bad. Test it here>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
SOURCE: walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
