Changed compressor / expansion valve / diode/relay/ accumulator sock. vacuumed down 1 hour with recovery system and recharged to 1.37 lbs 625 gm. Note. if i play with relay it it will work for about 10 min then stop working again. The whole problem started all of a sudden when wife stopped at store worked great until then. Please help
Make sure radiator and or condensor fins are not restricted with dirt , bugs etc. poor airflow across the condensor. high side pressure could rise too high causing compressor to cycle off and on and not cool the freon properly.not sure what you mean when you say you play with the relay and it comes on. compressor or the fan? pull the relay and look at the female pins and make sure they are not spread open too wide. is the check engine lamp on? sometimes computers will disable ac for some other faults. im not sure if you mean the compressor is turning off and staying off, or just not cooling well due to fan problem. if its turning off it could be a control head problem or the pcm disabling it for another reason. or if you are manipulating the relay then compressor kicks on you may have a bad relay. hope this helps
Also replaced triad switch with no resolution.
