Compressor seems to function proper when jumped at the fuse box where the relay belongs with paper clip. The A/C will blow cold air and reads 35-40 PSI on the low end and 190-200psi on the high end (paperclip installed). Everything works "proper" at this point. Once paper clip was removed and relay has been re-inserted compressor will not engage. And air turns warm again. It seems like the pressure on the high side dropped after turning the car off and replacing the paper clip with relay. I believe it was down to about 150psi. But I will have to reverify and repost its late and Iv had enough with it today. Thank you for all help provided.
SOURCE: a/c warm low and high side pressures wrong
it could be one of 2 things.
you didn't vaccum it all the way or there is b clog in the system. next time u flush it run about 1/8 cup of rubbing alcohol through it . then push clean air through it. then refill it. if that doesnt work replace the seals on the compressorlow and high side lines/manifold.
SOURCE: 96 Tahoe no Cold Air
Yes... you are most likely low on freon as the compressor will cut on low pressure before vacuum.Depending on ambient temps and head pressures your running ,you may see low side pressures at 50. Automotive refrigerant (134a) is not far from matching the degress to low pressure....for instance 50 lb low side pressure will give you approx 60 degrees cooling at the vent.Once cabin temperatures are met is when you can expect that suction pressure to lower and stabilize.You would be better off watching high and low pressures to get the full picture of whats going on here...good luck
SOURCE: 2008 cobalt with 16000 miles ac went out last fall
It sounds like your A/C condenser is freezing up. Possibly from having too much or too little Freon in the system.Is the compressor clutch engaging, it should engage.If not the clutch is problem.-------
Other possibility can be moisture in the system and its freezing/thawing in your expansion tube blocking the orifice .----
There is a pressure switch that would not allow the compressor clutch to engage until there is a certain pressure in the lines.--------- The refrigerant level is low in the Ac compressor.The refrigerant needs to be charged.------ If the refrigerant level is insufficient the compressor will not engage. If it is very low the compressor will cycle on and off. ---------Get the Ac fan ans compressor clutch relays checked in the engine compartment under hood.If the relays are checked ok, so try this ,jump the compressor relay by a hot wire and then see the clutch should engage.---- ------------
There is low pressure switch on the compressor.Jump the low pressure switch by a hot wire and see.If the clutch engages, if not then problem with the clutch.------- It has to be replaced.-------- This will help.Thanks.Helpmech.
