It says it's reading the cd it spins and then goes to the next cd and does the same thing
SOURCE: won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
SOURCE: CD player won't play
Sounds like the reader (laser eye) is dirty. The reason why it says "read" is beacuse it is looking for a disc to play, it's not actually reading the disc, more like searching for data to read. Even if you have all five discs in it still won't play. It's like looking through a dirty windsheild, nowing that there is a road there but you can't see it. This is a very common problem and is easy to fix. Go to your local Walmart, or electronics store and purchase yourself a cleaning CD. It will look like a regular CD but with small brushes on one side and might come with some cleaning solution too. Shouldn't cost more than $20.
SOURCE: cd player shuffles through all discs, but won't play
contact Durabrand at 1-800-252-6123 or Venturer Electronic
203 Eggert Rd,Bufflao New York 14215-0248
SOURCE: my jvc cd player will not play the cd it says read
the optical pickup (lens and laser) is dirty and needs cleaning. you can buy a **** cleaner and use it regularly, but if you need it too often, you'll want to take it apart to clean it.
SOURCE: player will not play cd - it reads then says
Your CD player is failed. It will need to be replaced. Some folks can repair but it cost less to have it replaced. If no one local will do it BOSE will for about $150.
