Bulb look ok but not sure
SOURCE: Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
SOURCE: Nec Lt245 power light yellow - orange status blink red
- Unplug the projector for a full 4-5 minutes.
- Plug it back in and wait for the ready light and try it again.
If the above fails, replace the lamp.
If that also fails, it is likely a bad ballast.
Thanks,
Tor
SOURCE: HELP! I changed the bulb already. My NEC VT 470
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
