A QO220 breaker will provide 20 amps of power at 240 volts when connected to #12 copper wires.
Smaller wires can not be connected as it will result in a code violation - and they are not rated for 20 amp loads. Depending on the device to be connected, it will have a total of either 3 or 4 wires. (2) hot black, red or blue wires and (1) ground green wire. Four wire devices provide (1) white neutral wire as well.
Three wire devices will provide a bare or green ground and 2 hot wires. The two hot wires should be black, red or blue - but in the case of building cables like Romex - may simply be a black, a white and bare or green. The black and white in a 3 wire cable used to provide 240V are both hot, and bare or green is ground. There is no neutral in this case. The white wire should be marked with red, black or blue tape, paint, etc. where ever it is visible so that people know it is hot - and not a neutral.
Bring the cable into the panel and locate the ground bar and the neutral bar. The ground bar has only bare and green wires connected to it and the nuetral bar will have only white or gray wires connected to it. Connect your green ground to the ground bar and any white or gray wire to the neutral bar. Most homes with the service disconnect switch inside this panel have only one bar that serves both ground and neutral wires. If your panel has ground and neutral wires mixed together, you can bring the white and green/ bare to any open terminal in the ground / neutral bar. Don't put more than one wire into 1 terminal.
Next, install the QO220 breaker.
The remaining 2 hot wires should be routed and connected to the QO220 - one wire to each of the terminals. It does not matter which terminal gets which wire as long as they are in two different terminals.
That's how it is done. Good luck!
