I washed my gas grill with the garden hose, now it won't start
Regulator. Tanks were non burped... Regulator stuck. Turn off tank slow. disconnect. Turn burners on. Tap the regulator with a piece of metal. Turn burners off. Connect tank. Since it was washed out electric starter dont work. Turn burners on. Then you will hear it. Gas. Take lighter and start. Big startup. The hair on your hand burned off wash your hands. Then get the meats! Easy as Cake
SOURCE: Brinkman gas grill won't start.
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
SOURCE: when i push igniter it
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If
the above didn't solve the problem, the Hose/regulator Assembly needs
to be replaced. What happened was this, when you turned the tank upside
to "burp" the tank. The OPD Valve shot a hot load of gas to the
regulator, when you opened it, as you normally would and permanently
locked up the grill's regulator. That "burping" trick used to work with
the old style tanks. Won't work with the new ones. You can get a new
hose/regulator assembly at any home center or hardware store, that
sells grills and accessories. They run about $30.00. Take your old one
with you for comparison purposes. Once you install the new one and
connect it to the tank. Open the Valve Very, Very Slowly, until it is
fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
SOURCE: Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
SOURCE: brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's
Hose/Regulator Assembly. It runs about $30.00 at any home center or
hardware store that sells grills & accessories. If you replace it,
turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
SOURCE: When I try to light
What you have is delayed ignition. It's being caused by the gas regulator. It is solvable, though.
Once the valve is fully open, light 1 burner and turn it to HIGH. Did the burner light and does th eflame height look correct? If so, light the remaining burner the identical same way. Now, to both flame heights look correct? If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly. And always light the burners with the Lid/Hood Open.
If the above did not solve the problem, you will need to replace the Hose/Regulator Assembly. Since your grill is brand new, the Hose/Regulator Assembly will be covered under Warranty. Have your Proof of Purchase handy and call Weber 1-800-446-1071. Also, if you haven't done so already, register your grill before calling http://help.weber.com/register/ even if you don't need a new Hose/Regulator Assembly.
Hope this helped you troubleshoot & solve the problem.
