Board #A136948A
SOURCE: standby blinks 7 times
The part # for the d board is A-1300-319-A pts corp can rebuild it for about $250 www.ptscorp.com
SOURCE: Sony KV40XBR800- My Sony blinks 7 times.Does
i would love to tell you that these are the for certain parts but i can only tell you without looking at the tv the parts that could be the possible culprits. the horizontal deflection has stopped. could be Q8035,8038 has shorted on the D board. this is the answer that my research has come up with. please rate my solution. thank you.
SOURCE: Sony KV-36HS420 would turn on
Check filament/ heater glows in picture tube neck?
5 times led blink shows that picture tube is not working.
If heater in CRT is not glowing (little orange light) that means either horizontal deflection section is not working or heater connection is broke.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
