Stihl Ts400 Top Cover Trigger Logo
Question about Stihl Ts400 Top Cover Trigger
Trigger mechanism on ts400 stihl saw came apart
It came apart dont know how it goes back together the inside of mechanism flew everywhere when i tried to get spring from carb back into place
Posted by joeloveroisi on
Plink-plonk
  • Stihl Master
  • 1,807 Answers
I'll send you a link of the parts diagram.
Posted on Aug 02, 2013
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 • Stihl Saws
Stihl ts400 starting problem
sounds like your getting air leak around a gasket
Stihl ts400 throttle stuck open and trigger stiff
Hi Mate, Got the same problem, Have found the service manuals for the TS400, and looking at it I think it's a problem with the throttle rob connecting to the carb.
Did you manage to fix it ?
CheersSteve
Jun 14, 2012 • Saws
15helpful
How do i set up the carburetor on a sthil ts400
The ts400 has 2 adjustment screws. First pop out the rubber gromet to see the screws. The one on the left is the mixture, the one on right is the idle Turn the idle screw in a coup[le turns, this will help the saw run a little fast Now screw the mixture screw in till it bottoms .now back it out 1 and a half turn. Press the decom and pull it thru with the , the choke on a couple times, now pull up onthe decom. Try to start it. when it starts, let it runat a fast speed moving the choke off a click or two when the motor warms up, idle the engine as muchas possible, then adjust the mixture screw in or out torun the best. Squeeze the trigger if engine faulters, it's to lean, back mixture screw out slowly, till it suits you. Reinsert the gromet.
Need to know belt size fo the stihl ts400 concrete cutoff saw
You should go to a Stihl dealer and ask for the belt for a TS 400 Cut Off Saw. The belt is ribbed, you should only put on a Stihl part to replace the belt and make sure the belt is under the correct tension. When you go to the Stihl dealer you can ask them to show you how to make sure the belt is under the correct amount of tension.
Does the TS400 need engine oil apart from 2 stroke mixture
Hello. No, the oil mix is designed to do all that is necessary. Stihl 50:1 two stroke engine oil or equivalent is recommended for proper operation, cheap oil does not have the additives needed too keep rings free and inhibit carbon build-up. Also do not use BIA or TCW rated oils, or any others with duel purpose ratings.
Thank you
3helpful
Stihl saw TS400 will not get fuel through,NON START
how much fuel can be put into a stihl saw ts 400 and how long will the fuel last while in constant use
Top Stihl Garden Experts
ray gallant
Joseph Hoffmann
Thomas Perkins
Thomas Perkins
Are you a Stihl Garden Expert? Answer questions, earn points and help others
