Possible the main relay in the power supply board may need soldring or you could have a stickey relay
thank for the reply i will check it, thank again.
David which is the main relay and where on the board is it location. Thank's
solved
SOURCE: PHILLIPS PLASMA TV MODEL #42PF9431D/37 Heard
Hi, Usually any "Pops" are an Electrolytic Capacitor "blowing up" quite literally, or "Gassing" as it is called. This happens due to some sort of power problem. Capacitors hate AC Voltage and Current, and Heat and Over Voltage. All of which, I have no doubt it was exposed to before it went "Pop" This is only a symptom of a far greater problem, to come, no doubt, soon, the rest of the set will fail too. Please DO NOT USE. this set any more, you risk fire or explosion or both. If you MUST use it at least unplug at bed time. Theses days home repair except for the most rudimentary problem is not feasible, setting aside the safety aspect. In my professional opinion, I would recommend, that you get a "Quote" for repair from a Philips Authorised Service Agent This is very important, that you contact a Philips head office and ask for a referral. This way at least you can make a decision to repair or replace.
SOURCE: cant find audio out jacks
This TV has a headphone jack on the side (above the Side AV input), a digital audio output (SPDIF) in the main input/output panel (bottom facing down) and two pairs of +/- terminals for right and left speakers. The terminals are to the left of the power cord. The SPDIF port is between the PC in and the AV3 in.
The terminals are used for directly wired speakers. Usually these have a pair of flat wire cables and the ends may have different color insulation (red, black, white, white/black striped).
If the speaker bar uses RCA inputs then get a 3.5 mm (M) to RCA (2 female) adapter for use with an RCA audio cable or an audio cable with 3.5 mm M on one end and 2 RCA plugs on the other. Plug the 3.5 mm end into the headphone jack of the TV. If you use the headphone jack, the TV speakers will probably turn off automatically. For the other audio options, you will need to enter the menus to adjust the settings. Press Menu and then go to Sound for speakers attached to the terminals. Digital Audio is adjusted from the Installation Menu then go to the Source Menu.
If the sound bar has a digital audio input, you should use that SPDIF cable (not usually included with the sound bar or the TV).
For details and a picture of the jacks, see http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=37PFL5322D/37&slg=en&scy=US for the User's manual or the leaflet (both include diagram). The User's manual has the picture on 3 (Section 2:2).
I hope this helps.
SOURCE: My 37PFL5322D 37" LCD has no picture and no
Pictures in my albums and my guides may help you out also.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Phillips model 37PFL5322D/37
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
could you tell me where it is located on the powerboard, david hogan. i would greatly apprecate it very
question to the solution. where is the relay location on the 715T2484-3 power board. would appeciate a answer
David the clicking seem to coming frompart number 80?TL37T912HJ DV_130_1 7022Q it also has HJC-S6191 Thank you
need to know where this relay is located David. Thank You
The set has been repaired. It was the power board. Thank you
solved
