Sharp R-1872 Convection/Microwave Oven Logo
Question about Sharp R-1872 Convection/Microwave Oven
Baked a cake and noticed the next day that there is no power, the microwave has just stopped working, no power coming through. Have checked the power switch and the power outlets all working fine except that there no current coming through to the microwave oven
Posted by Tony on
ernesto cuadra
    Top Expert:
  • Sharp Master
  • 12,223 Answers
Test the thermal fuse for open or bad contact with VOM
2)check the hooks door, or release door button, +switch door for open with VOM.
see the diagram for troubleshooting.
Gd bless you
Baked a cake and noticed the next day that there i - 7_15_2012_12_31_39_pm.gif7_15_2012_12_32_15_pm.jpg
Posted on Jul 15, 2012
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave oven inoperative
When you enter the time then hit START, does the turntable motor come on? If not, then I would suspect the secondary interlock switch, its mount, or its wiring. If so, then it's hard to say, unless there was some miswiring somewhere. The original problem sounded like just a classic bad door switch. At this point I suspect the wires on one of them may not have been reconnected exactly where they were. It does matter. I would suspect the secondary interlock switch, which MAY have white/white and grey/grey wires attached. Also, one of the switch mounts may have a broken tab that makes the switch move so it's not getting activated. At our site, we have the service manual for the R1830, which is similar to the R1480-series. We have that plus *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 27, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Posted on Apr 26, 2007
check high voltage section, check magneatron, diodes, etc.
Posted on Nov 04, 2007
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
Anonymous
  • 1550 Answers
SOURCE: My Sharp R-9h91b microwave oven
The continuity of current is lost you need to check the continuity by multimeter .Then we can get idea what causes the problem ?
SAM ANDERSON
Posted on Sep 28, 2008
I have a R-9H20 Convection oven works fine but blows fuse (10A) after few seconds when microwave selected
Sounds like MW has failed. given the age of unit repair is not economically feasible. I would buy a new unit and forget it.
I do not know that could I bake cake in Panasonic NN-G335WF/MF
Hey, anything is possible! Even I have baked a cake in one. Use Panasonic's cook book, or something else from a wonderful author like Betty Crocker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
What is convection cookong
A convection microwave is a combination of a standard microwave oven and a convection oven. It allows food cooked in the convection microwave to be cooked quickly, yet come out browned or crisped as in a convection oven. However, most cakes cannot be baked in a microwave oven - only those without an open grain structure, such as brownies. There are microwaves which contain electric browning baking elements. A true convection microwave has a high velocity forced air fan to circulate the hot air uniformly.
more about Convection microwave
Lg lmlv2055sb just stopped working
6 years may be the point where the repair could cost more than a new unit----Call a local shop to see what it costs to look at the unit and if possible get a ballpark estimate---then weigh repair versus replacement.
Goldstar microwave mv1501w stopped working
Check the fuse in the unit, little white body. it is 15 amps
What time will i set forhalf kg. of cake on bajaj microwave
The time depends on the ingredients used on the cake as well as the power used by the microwave or convection. So it is important that this is checked or you will have a burnt cake.
On the other side you can start with a lower timing and power and then proceed after the cake is checked which might be safe.
1helpful
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
I have an electrolux convection model. the manual does not have suffiencient information on how to bake a cake. could you please explain me the precedure interms of the power selection, time required,...
Firstly I would suggest contact Electrolux for more info.
But in general all cakes are baked and no microwave energies are used.
An oven timer is critical to avoid over-baking.
Microwave Keypad Is Hot
check blower fan, and maintained gap between oven and wall at last 2 feets. some heat comes to pad very heat may be some prolem. check every thing and reply me.
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
