Yesterday, my pictures were displaying. Today the screen is black and the frame will not turn on, though there is a green light on where the on/off switch is. No buttons will respond and the screen remains completely black like it is turned off but it is on. The frame is warm like it is on, but no pictures will display and the buttoms are nonresponsive.
SOURCE: no pic/sound
If you dont here anything then it sounds like the switching power supply or the horizontal output circuits not starting up. this requires troubleshooting with a variac, as well as maybe a scope. If your not trained to work on HI Voltage circuits you should seek assistance with this repair. Theres HI voltage inside these sets even after they are unplugged for a while. sorry i couldnt be of more assistance.
SOURCE: Black Screen after 5 mins. of use
It sounds like the entire screen goes blank with your problem. My problem is the lower half of the screen goes blank. Do you think the SSB is also the problem? What are your thoughts about the "Video Board" or the X Board?
Do you know where to purchase parts?
SOURCE: dictaphone does not turn on
There is a small hole in the back of the unit. This activates the firmware update. My experiense is someone pushed this in with a pin and caused the switch to be stuck. You can disassemble the unit and use a pin to pry the bubble switch up or off. This switch is only needed to update the firmware which can also be done thre software so is not needed.
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
SOURCE: Magnavox Philips 26MF231D 26 in. LCD Television
Most likely you have defective capacitors in the Power Supply. It is not an expensive repair but something that needs to be done by a svc. co., if your not familiar with Switch Mode Power Supplies (SMPS). I hope this helps and Thank You for using FixYa.. Let me know....
I have the same problem. In the off mode the red light is on (near the on-off switch) and when I switch the unit to on, there is a quick flash of red across the screen and then the green light on the back of the unit remains on, but no pictures show.
I have exactly the same problem. Its been working fine for a year or so, now the screen is completly blank, the powere button appears to be on (ie it is lit up) but the buttons are not responsive. Obviously ive tried recharging etc, but no response.
I have the same problem. The frame is plugged into power in the wall, which is stable. If I unplug it and plug it back in, it will work for a while but then it will go black again.
Same problem. The only way to loose the power lights is to press the reset button. I'd be keen to know what the fix is for this.
Same problem. when i turned on, the screen is blank. The power button shows green but, it didn't change even, when we press reset button.
Appreciate any kind of solution for this.
I have the same problem... Some troubleshooting advice is available at phillips.com (says to try resetting it and stuff like that) but that stuff didn't work for me... Help!
Also, it appears on mine that the screen is not totally black, just extremely dim. Turning up the brightness didn't work either
