I've tried just about everything from pressing top left corner while powering on...pressing lower right corner while powering on...holding the power on/off button for 8 or so seconds...unplugging the battery for a few mins. or so...no luck. When I turn it on it goes to the garmin screen for about 5 seconds then it's like it reboots it self then back to the garmin screen (relooping) until I turn it off.Help!?
SOURCE: garmin stuck on foreign language
Turn the unit off. push the lower right corner until the unit comes on. a page will appear with the arabic and it will show 2 radio buttons push the right hand one and it should reset.
SOURCE: trying to reset my garmin nuvi 350 but per-boot
(G-Brand): Place your finger over the lower left-hand corner of the screen (upper left-hand corner for a 6xx series) and hold it there while pressing the on/off power button. Keep holding your finger there and a window should pop up asking if you want to go into maintenance mode. Select yes. There is an option called "clear user data". Select that option. It will not erase your favorites. It will however, erase any corrupted satellite data and will default you back to some factory settings and to a location of the manufacturer's headquarters in Kansas. This will also force your GPS to collect new satellite data. Your GPS should reboot and it will ask you a couple questions like, timezone, language. Please select the proper settings.
- Jim
SHARCNET-USA
SOURCE: Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
SOURCE: hi my garmin nuvi 255w keeps powering off
Try resetting the unit and also charge it using only the wall charger overnight.
Here's how to reset -it just puts everything back to factory settings -
1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture.
2-Select YES
PLEASE Take the time to vote me up this is my only reward for trying to help.
Thanks
PIC 2
SOURCE: nuvi® 255W Car GPS Receiver: The screen of my Garmin nuvi 255w GPS is white and...
Press and hold the lower right corner - then see second picture
