The air conditioner blows cold air for approximately 5 minutes before blowing out unrefridgerated air, and my venting exhaust hose get really hot.
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer
Affairs Representative from within the United States, please call
1-877-254-4729
SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
SOURCE: no cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
SOURCE: Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
SOURCE: Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
