Canon DR-3080CII Path-Through Flatbed Scanner Logo
A
Anonymous Posted on Jul 12, 2012
Canon DR 2010c failed to load - Canon DR-3080CII Path-Through Flatbed Scanner
2 Related Answers
Anonymous
  • 124 Answers
  • Posted on Dec 10, 2009
SOURCE: Canon DR 2010C not recognised by computer at start-up
Go here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=16044
The one you want is the CP Upgrade 3090
Hope this helps
Please leave feedback
Testimonial: "have not checked to see if the fix works yet"
Lynne
  • 102 Answers
  • Posted on Oct 29, 2010
SOURCE: My scanner won't scan. I
This may mean that something is using it or that something is interfering with it. Try turning everything off, your computer AND your scanner. Wait a minute or two and then turn your scanner on first and the turn your computer back on. When your computer boots back up don't open anything except the scanner. If your still getting the message then there is something else (another attached peripheral) that may be interfering with the scanner.
I can't figure out how to download the needed "WIA Driver"
Drivers are located here. Follow the three steps listed to get the proper driver, and then download to computer. http://www.usa.canon.com/cusa/support/consumer/scanners/document_scanners/imageformula_dr_2010c_compact_color_scanner#DriversAndSoftware
I hava a canon dr-2010c scanner. but when I scan the paper through capture touch 2.0 than scanning very fine but when I scan through capture perfect 3.0 than show black page scanning.
Normally it is advisable to use only one Scanning Software. The software has various files which may overwrite the previously installed version. The later version works good.
It is also possible that the brightness/contrast settings in Captureperfect 3 is not proper. Try scanning after altering these.
S. Mohan, India
Twain canoscan
It looks like the manufacturer has what you need - http://www.usa.canon.com/
Canon DR2010C scanner pausing
HI. Maybe is slow because a low Ram memory in the pc
3helpful
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam [email protected] 9210845186
My scanner won't scan. I get the message " Scanner is busy, operation can not be completed. Canon DR-2010C Driver Version 1.1.10805.18001 (-4437).
Hello
Hello
Do you have a question?
Let me know.
Kind regards
Andrea
Where can i get roller kit for canon dr2010c
Here's one place.
http://www.porthale.co.uk/products.asp?partno=2445B001AA
For somewhere near you just Google roller kit for canon dr2010c
old marine
old marine
ZJ Limited
ZJ Limited
