Question about Intel Motherboard
I have a K52f that I had to replace the dc board on. Now it will not turn unless I pull the CMOS battery out. Once it booted up it is fine, except the screen is so dim I can barely see it. I can reboot or put it to sleep without a problem but if I shut it down I have to pull the CMOS battery again. Is it the motherboard? Any help is appreciated. I tried the whole holding the power button down thing and it did not work. Jeff
Posted by jffryams on
crexter
    New Friend:
  • 28 Answers
Your mother boards was defective already. look in your MB if thre is some blotted caps in your Bourds. and if they are present in your MB it is necessary to change your MB for the safety of your data. in near future
Posted on Aug 21, 2017
How can i clear start up password on an ASUS k52f?
it should have worked when you took the battrey out
Jun 24, 2014 | ASUS K52F Notebook
I have a Probook 4520s checksum error on cold boot. Time and date is reset to 1979 but everything works fine after adjusting both date and time. I changed the CMOS battery and flashed the BIOS. Same...
You need to replace the small bios battery or CMOS battery if you changed it and it didn't work the battery was probably dead. Pull and test the battery. If the battery tests good yep you may have a board motherboard problem. Check the new battery first test any new battery it could be dead on the shelf always good to find out.
Oct 21, 2013 | HEWLETT-PACKARD Computers & Internet
Pavilion dv4 1220us blink code 1
have you unplugged, remove battery, plug in, reboot? Try another Cord/Charger with the EXACT same power specs. Has there been any damage to the AC jack due to pulling on the cord while plugged in? Verify your DC voltage at cord plug that fits into the AC laptop jack. Have you reseated/replaced the Memory Mods? The CMOS battery? The HDD ? It sounds like a Power issue as it the Cord/Charger/AC/DC Transformer? Hard to say from here without a MultiMeter to verify. Look at HP support: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3860431
Apr 20, 2013 | Computers & Internet
After replacing on board lithium cell, computer will not boot up. Goes through BIOS ok but no further, even tried replacing hard disk and booting from removable media drives (after setting BIOS...
Did you swap the Cmos jumpers from 1-2 to 2-3 to clear Cmos before replacing battery and if so, did you return them to their original position (normal as opposed to clear cmos)? If the jumper is still in the clear Cmos position, the board will not boot.
Try changing the Cmos battery, it may appear to work but may not be suited to the board
Disconnect all drives except the hard drive, unplug usb and sound cables, if fitted, remove graphics card and either test with another one or use the onboard graphics.
Jan 11, 2011 | ASUS A7V333 Motherboard
Hi... i'm using DG31PR intel motherboard. for the past few months am getting these errors while booting... CMOS CHECKSUM ERROR CMOS BATTERY FAILURE i've replaced many new CMOS batteries.. but still not...
I would reset the CMOS. This is done by removing that CMOS battery. Also, find the jumper that says "J-21" and move it to the alternative position. The jumper is located on the motherboard. Boot up without that battery in , and choose "Reset" that should clear out the junk. Also, replace the battery. Go to www.intel.com and look for a "bios update" the DG is a value board. a huge value board and one of Intel's bummer boards. Update the firmware. Once you do that, you should be good to go.
Nov 07, 2010 | Intel D101GGC Motherboard
I have an HP Pavillion a1250n which has a MS-7184 V1.0 that will not boot. When turned on the HP Invent logo screen appears with thw following at the bottom:(Esc=Boot Menu)(F1=Setup)(F10=System...
It sounds as though you might have a problem with BIOS.
You should remove your motherboard battery (little round silver disc) and if you can find (or Google motherboard model#) the CMOS reset jumper, you can remove the battery for 30 seconds and put it back in and reset the CMOS, then see if it boots. If it doesn't, you might need to flash the BIOS, which is not recommended unless you know what you are doing.
Nov 16, 2009 | Intel Motherboard
My pc can not find boot device
there's a system rechargeable battery inside the PC casing which helps retain system settings. it may have given up the ghost. you could try replacing the battery...
Jun 01, 2009 | Intel DG33BU G33 Express Socket 775 mATX...
Computer won't boot up after attempting to install new memory
I believe resetting the CMOS would fix this problem. To reset the CMOS, open up the computer and locate a battery similar to this one (it's on the motherboard):
Once you find it, pull it out. Leave it out for about 24 hours (one day) afterward placing the battery back into its slot on the motherboard. Now try booting up.
It should now successfully start up requesting that you make changes to the BIOS since the CMOS was just reset. Afterward you should be able to use the computer normally.
NOTE: Try resetting the CMOS with the original RAM inside the computer. The new RAM might be forcing the motherboard to send too much voltage or use an incompatible Mhz setting to support the new stick of RAM.
Let me know how it turns out and if I can do anything else to assist you.
May 15, 2009 | Dell Dimension 3000 PC Desktop
Evo 610c won't turn on
see may be your battery is completly discharge everything is ok just charge it completly it will work
Oct 08, 2007 | HP Compaq Evo n610c Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Intel Motherboard Logo
970 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
