You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
hope it helps
SOURCE: USB Write Protection
Put the memory card into the SD adaptor and turn the white switch on the left of the card in the opposite direction.
See if that will work.
You may have to turn your phone off and back on again as well after reinserting the card back into the phone.
SOURCE: I can't seem to remove
Try with my property click here , choose download - and download winsetup from usb.
Try format with this software ,
if still error, contact me.I will help you my friend.
SOURCE: I hava a memory card,
Here's a simply suggestion which I suspect you have already tried.
Many SD cards, such as the the one you see in the picture above, have the "lock". On the left side of your card you should see the lock. Turn the lock off and try connecting it again.
Like I said I assume this isn't your problem (since you know what a "registry" is ;) ) but the problem you described is exactly what happens when the "lock" is on. That's my first advice.
Thanks for using FixYa.
Permissions in the PC may have restricted writing files to the USB flash
drive. Disabling restrictions should fix this issue.
WARNING: Backup your registry before editing.
STEP 1 - Backup the registry
1. Unplug the USB
flash drive.
2. Click Start > Run, type in
regedit then click OK.
3. From the
registry menu, click File, select Export.
4.
Under Export range select All.
5.Name the file SNDK.reg and save it to
the desktop.
STEP 2 - Disable the "Write Protect" permission in
the Registry
1. On the left pane, click the "+" beside
HKEY_LOCAL_MACHINE
2. Navigate to SYSTEM > CurrentControlSet >
Control > StorageDevicePolicies.
3. On the right pane, right-click
on WriteProtect and select Modify.
4. In the Value data field, type the number
0
5.
Click OK.
