Question about Panasonic KX-T7730 Corded Phone
How do you change the name? I have got up to the part where you enter a new name but as i go to type for example : victoria it just comes up with 888444 how do you get into the alphabet mode?
When you have pressed the number 8 press the auto ans and it will then scroll through the letters TtUuVv so just keep pressing that key untill you get the letter you want then press the next number for the next letter followed by auto ans etc and do the same for a space
Posted on Jun 13, 2013
SOURCE: Panasonic KX-T7730 Corded - change display
On mine I press the asterix to toggle display options
Posted on Apr 08, 2008
SOURCE: Changing the names for extensions
Name changes are done from the System Administrators phone. In the TA-series, it's system program 604. In a TAW it's 004. I can give you complete instructions, but you have to get to that screen first.
If you get there and want to play, the SP Phone FWD CONF MUTE and keypad press up to 7 times enter the Alphabet names (space is under 1). Nothing writes until you press STORE.
Carl
Posted on Oct 30, 2008
SOURCE: lock extension with my Panasonic KX T7730
Do you need the default lock code because you already did this, or is it locked and you can't unlock it?
This is probably close, but in the American version it's 77 lock lock # to set and 77 lock # to release, where lock is a 4 digit number.
The System manager can release all locks from their phone. You'll have to make arrangements with an "engineer" to get those codes.
Carl (working on Br terms)
Posted on Jul 18, 2009
SOURCE: panasonic kx-t7730
Hello, if you are using this phone with a 308 or 824 system, while the handset is still on the cradle / hook press PROGRAM and then the one touch button you want to assign a CO line to. Now press 0 followed by the line port number ( example 1 ). Press AUTO DIAL / STORE to save the changes. Press PROGRAM to exit program mode.
PLEASE vote if this was helpful
Posted on Mar 24, 2010
SOURCE: how to set the clock at a panasonic kx-t7730
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
password ( default is 1234).
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Posted on Mar 28, 2010
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
Mar 23, 2010 | Panasonic KX-T7730 Corded Phone
Mar 09, 2010 | Panasonic KX-T7730 Corded Phone
Nov 19, 2009 | Panasonic KX-T7730 Corded Phone
Jul 17, 2009 | Panasonic KX-T7730 Corded Phone
Jun 27, 2009 | Panasonic KX-T7730 Corded Phone
May 18, 2009 | Panasonic KX-T7730 Corded Phone
Oct 30, 2008 | Panasonic KX-T7730 Corded Phone
Sep 18, 2008 | Panasonic KX-T7730 Corded Phone
Jun 18, 2008 | Panasonic KX-T7730 Corded Phone
1,184 people viewed this question
