Question about Pride Mobility Products Health & Beauty
Pride mobility scooter died after bogging down and tripping the fuse repeaedly
We just changed the batteries. the keeps blowing and needs to be reset. it bogs down and now it is completely dead
Posted by linda boutot on
George Freed
    Novelist:
  • 60 Answers
IT sounds to me like you have one or more shorted windings on the armature of your drive motor which is apart of the trans-axle assembly. TO BE SURE remove the entire trans-axle module. I have a Rascal 600t all i have to do to remove my trans-axle is to remove to quick pins and my entire trans-axle assembly comes away from the scooter. Take the entire assembly down to your local motor repair shop that can rewind motors. Thay will check out the motor, take it apart and clean all the carbon dust from the brushes that gets all over the interior of the motor, doesn't do the motor bearing any good. Rewinding a motor isn't inexpensive costing $200 and up depending on the size and complexity of the motor. But the scooter trans-axle cost is astoundingly high at $1,500 and up. They say they are sealed unit and that they can not be repaired. In reality trans-axles are quite simple to repair and easily repaired. The only difficult thing are the scooter companies that will not come across with the parts and info we need in order for us to keep our scooters in good repair. So ii'd take the trans-axle down to the motor shop. They don't charge anything to check it out. When they do maintenance you will know its working right. When troubleshooting problem with scooter you eliminate half the machine when you eliminate the trans-axle. Get back to me once you've checked it out
Posted on Jul 18, 2012
5 Related Answers
ruddski
  • 7 Answers
SOURCE: I own a pride mobility scooter with an issue of stopping
It could be a loose battery connector and the controller heats up when it's trying to pull amperage out of the batteries but can't because of the loose connection Try tightening bolts on batteries but disconnect them first. Also it could be the brake on the motor and if the unit isn't shutting off the lights on the tiller blink in patterns to let you know what problems to check for.
Posted on Mar 10, 2009
Anonymous
  • 40 Answers
SOURCE: wiring for pride rally scooter.
Sorry but your probably going to have to get this to a service technician. That is a big problem you have there. Most wiring is`nt even color co-ordinated so it`s not a matter of matching up colors. I`d call a professional,
Posted on Apr 03, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: my battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Posted on Dec 25, 2009
Testimonial: "Thank you for answering. "
Neil Wood
  • 177 Answers
SOURCE: Pride Celebrity Deluxe Mobility Scooter - Serial Number
Hi. The serial number will be on a sticker on the upright support that holds up the seat. You will have to lift of the seat, and take the cover off the batteries to see it. It should be on the front of the deat support. Neil.
Posted on May 27, 2010
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: my pride go go scooter beeps and then stops on me
mcdevito75 here, Return to the repairer for more repairs, maybe a circuit board needs replaceing.
Posted on Jun 23, 2010
Battery indicator voltage keeps going down
sounds like loose battery terminals or a bad ground from battery to engine and frame
Feb 27, 2014 | Cars & Trucks
1999 Kawasaki ZX-6R Ninja keeps blowing the main fuse
Hi, Mooncat1970 before diagnosing your blown fuse issue, check the bottom of your seat, if its metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Electrical Main 30A Fuse Keeps Popping ZX Forums
Ignition and Main ECU fuses keep blowing
Kawasaki Ninja ZX 6R 1995 2002 Service Repair Factory Manual Download... $15
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Aug 27, 2011 | 1999 kawasaki ZX-6R Ninja
I took it in to replace my battery and the air was blowing cold....after the battery was changed the air immediatly was blowing heat and when the air compressor was trying to kick on it would bog down the...
a memory saver should have been used when changing the battery. however the hvac control module will need to be relearned. this can be done with a scanner that can access the hvac module or you can take it to the dealer. but to replace the actuators in the climate control system the dash will have to be removed .
Jul 26, 2011 | 2003 Chevrolet TrailBlazer
IT KEEPS TELLING ME TO CHANGE THE BATTERIES (EVEN WHEN THEY'RE NEW BATTERIES) AND SHUTS DOWN COMPLETELY.
Couldn't find a firmware upgrade for my Canon PowerShot A720. Tried putting a piece of rubber under the spring on the lid to make it tighter and it helped because I can take more pictures before I get the dead battery message (even thought they aren't dead). I bought the Duracell that you can check the charge on because I'm sure I've wasted dozens of batteries by now.
Aug 31, 2010 | Canon PowerShot A720 IS Digital Camera
Bogs down & spits back through carb.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
Sep 19, 2009 | Polaris ATV
The starter will crank a couple of times, but doesn't start. The clock in the vehicle reset itself, possible dead battery? It will sometimes crank, and bog down like its not going to start... than it...
that's probably a weak battery, I don't think a bad starter would drag it down like that, have your battery and charing system checked, that'll fix it
if the alternator is putting out 13 volts at idle it's good
If you can get a larger capacity battery, it doesn't have to be physicaly larger, just more amperes output, and be sure to clean all terminals
Aug 10, 2009 | 2001 Volkswagen Jetta TDI
No power after 2000 rpm
changed fuel filter and disconnected batteries for 30 min. to reset computer. Truck is fine now
Dec 17, 2008 | 2003 Chevrolet Silverado 2500HD
996 bogging down then stalling
it starts to bog down and stall. on top of this the battery won't charge. Any possible knowledge on what's going on?Most likely you have a dead battery or a battery with a bad cell. Which can cause the problems you are describing. Also have you tested the charging system?,,,
Nov 10, 2008 | 2001 Ducati 996 R
Bogs down when step on pedal high speeds
its the fuel pump...........it will go completely out soon therefore your car will not start......replace it and you engine will not bog down.........you might also need a tune up.....if you havent had one in the past couple of years then you need it........
Oct 24, 2008 | 1997 Buick LeSabre
Health & Beauty Logo
268 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
