Question about LaCie D2 Extreme 300 GB Hard Drive
The drive has been working fine for quite some time. Recently the CPU tries to read the drive and a little autoplay box comes up with a name of one of my folders (often picks between several of the folder names) as it searches the drive. Sometimes it even is able to recognize the drive with my folders showing but as soon as I click on a folder it locks up. Eventually an error message appears that states "delayed write failed". I am using a belkin Firewire 3 port card.I recently reinstalled windows and the same problem still exists after installation
That error message usually means the drive is working intermittently (writing to the disk), and drive failure occurs shortly thereafter. You might try a different connection mode (USB?), and make sure you have everything on that drive backed up or copied elsewhere.
Posted on May 03, 2017
SOURCE: Can't access my lacie external hard drive
I would first plug it in to a different PC, this will tell you if the problem is the Lacie or Windows Vista.
if it works on a different PC then remove it from Device manager or go to the Lacie website for Vista updates.
If it does not work on a different PC then there are 3 possibilities
1. the drive got cleared data lost
2. the enclosure is bad (I would bet on this)
3. the drive is bad
purchase a USB enclosure, remove the drive and install it in the new enclosure plug in and test.
Hope this helps
thanks for rating
Posted on Jan 09, 2008
SOURCE: LaCie F. A. Porsche Hard Drive
Try this...
use a long bladed kitchen knife to get carefully spread apart the sides from the bottom plate. there are 4 small tabs along each side of the case going int 4 slots on the bottom plate. The long sharp blade inserts easily between the side and bottom plate.
Carefully pry the side away from the bottom plate starting from the front working towards the back. You gently twist the blade to get the tabs out of the slots. the first one is the hardest. After that they pop out easy.
to remove the hard drive mechanism, once you have the bottom plate off, remove the four silver screws--two along each side--then use the knife to separate the sides of the hard drive from the case, so that the front of the drive is angled up (you'll also have to pull the activity LED loose from its hotmelt glue), then slide the drive out of its metal mounting bracket--you won't be able to pull the drive out along with this bracket.
Posted on Jul 16, 2008
SOURCE: deleted 4 folders for lacie silverscreen 500gb
Dead easy, simply attached the SScreen to your PC/Mac and create the four folders:
"Movies"
"Pictures"
"Firmware"
"Music"
It requires these four folders to boot the OS!
--No Quotes in folder names--
Cheers
Posted on Sep 12, 2008
SOURCE: lacie hadr drive problem
Data recovery software.
Check this link:
http://www.software.com/view/8384/72/easeus-data-recovery-wizard-professional-4-x
Posted on Feb 07, 2009
SOURCE: Locked Folders
One week ago my LaCie external disk has been locked during a system reinstallation process in which the hard drive was plugged in. The message was that I had no permission to access it. I thought I would loose for ever all the files I have been backed up for years. But finally I have got the solution for that. There is a sofware called MacPilot (I used version 3.2.6, $20, 15-day trial) that fixes it. Once instaled, click TOOLS, then "Files&Folders" at left, then "Unlock File or Folder", press "Choose", it opens FINDER and then you click LacCie Disk. When the padlock symbol at the botton of LACie disapears, you can finally change the permissions to "read&Record". That's all, and I hope it helps.
I recommend that you always unplug external hard drivers during system reinstallation to prevent that.
Posted on Mar 04, 2009
Jun 01, 2014 | LaCie (301151U) 320 GB USB Hard Drive
Nov 20, 2012 | LaCie External USB 2.0 500GB 7200 RPM 500...
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Mar 23, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Dec 31, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Jul 05, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Jan 27, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Jan 12, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
Sep 04, 2007 | LaCie (300740) 160 GB Hard Drive
Apr 08, 2007 | LaCie mini (300998U) 250 GB Hard Drive
138 people viewed this question
