Printer say cartridges missing while cartridges are there and i know they regarding ink
SOURCE: black ink cartidge
If a black cartridge will not print, with no error messages, it is probably th printhead. Clean it with proper cleaning solution. Refilled ones if done yourself or by someone else, can also have air bubbles, Try blowing down refill hole with tissue under the cartridge to stop ink spills. Also, if you press a folder non scented wipe under the cartridge firmly, you should get a solid little black line or impression. This will tell you if the ink is getting down ok. Try reprinting.
SOURCE: ink cartridge missing
you can tell me plz which printer use u .......i hope u use both color & black ink cartridge.....go to printer
setup .......???????if your black ink empty you change your near pc Or printer vender........
SOURCE: Color Cartridge Missing
Please follow the steps given below:
1 Turn the printer/All-In-One off and unplug the power cable from the outlet.
2 Open the printer/All-In-One lid so that the cartridge carrier can be accessed.
3 Remove the print cartridges.
4 Using a dry, clean cloth wipe the carrier contacts gently from top to bottom.
5 Repeat Step 4 for the other cartridge slot (if applicable).
6 Reinsert the cartridges, slide the cartridge carrier to its original position, and close the printer/All-In-One lid.
7 Plug the printer/All-In-One back into the power outlet and turn it back on.
Next, try to perform a Self test:
1 Press the Copy button on the operator panel once (this button is located under Mode).
2 Press the Options button ten times until Maintenance appears on the display.
3 Press the left arrow button (-) once. The display should now read Self Test Page.
4 Press Select. The printer will print a hardware test page.
SOURCE: My printer wont accept my coloured ink cartridge
Is it the new original cartrigde colour or not ? If yes, you should ask a guarantee from the seller.
There is a chip inside the cartridge, sometimes it doesn't compatible for the printer software to read the chip.
The printer will keep asking for the new one if there is no ink in the cartridge.
SOURCE: lexmark x7170 printer cartridge error
Remove the color ink cartridge and double check that the plastic tape, which you removed from the cartridge is completely removed. I've noticed that sometimes a small piece of the protective tape tears and stay stuck on the cartridge causing the printer to give a false error. When replacing the cartridge be sure its fully inserted into the color cartridge holder and the locking mechanism locks securely.
