Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Default password to enter service of konica minolta bizhub C352
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Posted on Oct 19, 2008
Anonymous
SOURCE: SMB Scanning to a Macintosh
SMB can be a bit tricky on Mac as the aliases etc, & paths can easily overwhelm the MFP. Try FTP as a better alternative. Use "Locations" on Mac to setup a static ip# they can switch to when scanning. I have found the KM machines a bit more fussy than Canon with regards to SMB as you can usually browse better on the Canon devices. I have seen the "Reference" browsing on KM allow you to see into the Mac yet will not allow scanning to the set location. Our KM reps always recommend using the ip# of the device vs Netbios name. To me that sort of defeats the point of using SMB anyway. Scan to PC over SMB seems ok to computer Netbios name as long as DNS is registered & working OK on the LAN & WINS is properly configured as well.
Posted on Jan 21, 2009
Anonymous
SOURCE: Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Posted on Apr 02, 2009
Anonymous
  • 32 Answers
SOURCE: Konica Minolta bizhub C352 error code C-D010
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok
si
Posted on Jul 03, 2009
Anonymous
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Posted on Oct 10, 2009
Change c352 admin password
Mr. Gates, yes there is away to change the pw recommended you get a tech out to do it. Change admin pw not over the internet. Should have a paper work to back it up. Big time security thing Hard drive access and stuff
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 03, 2015 | Konica Minolta bizhub C351 All-In-One...
Konica minolta bizhub c451 service mode password reset
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Mar 14, 2014 | Konica Minolta Office Equipment & Supplies
I would like to teach me to scan the Bizhub C352, ie what are the steps to take to scan a document in BIZHUB C352. thank you Manuel Medina [email protected]
Mack a scan folder on your computer & share it to network the you go on c352 and press scan key - direct input / scan to SMB / reference / work group open / your pc name open / scan folder ok -you are ready to scan any document any help you con- me 919899653281
Mar 19, 2013 | Konica Minolta Bizhub C352 Digital Copier
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Oct 06, 2009 | Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
999 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
