SOURCE: Lost the charger for Kid Trax yellow corvette
Ya, kidswheels charges an arm and a leg for that charger along with most others. If you go to http://www.cammhsm.com you can get information on how to get around this kind of thing. You can get a $10 charger and do the same thing, although if your using the kid trax / safety 1st battery it is pretty much junk. It will keep failing on you, costing you more than $50. The charger is only one problem. Anyway, it is all documented and provided at the above site. Don't waste your money on these expensive chargers and batteries.
SOURCE: I have a Groovy Girls
Do you know how to access the battery.. ? Probably under the seat etc.. Does it look like a brick with 2 spade connectors on top?
6 volt 7.5 Amp hrs.... These are the same batteries as used in most computer backup power supplies. http://www.apc-ups-battery.com/newsite/6P1270.htm
If it's more square shape then it's the type used in emergency lighting 6 volt 4 amp hrs
http://www.lightworld.com/viewdetails.asp?id=99910252&sub=843.
These and many more are available all over the internet and in specialized battery stores..
Shop around . The examples here are fair prices.
SOURCE: Where can I find a
Hello Arey,
http://www.kidtraxtoys.com/skin/frontend/kidtrax/default/pdf/Chevrolet_Corvette_English.pdf
http://www.kidtraxtoys.com/spare-parts
