I presume you have Windows 7, right? If everything else is ok - printer working properly, you may drag the SmarThru icon form the start menu on your desktop.
How tosavedata Tosavedata, use softwarefullversion, for example,youcan useEASEUSData Recovery.After the data issaved, do therepairflashdrive.
Repairflash drive Kingston 1.Right-click theflashdrive,selectFormat- selectquickformat.Ifthis does not work, don'trepeat,dothesecond. 2.Format fromAdministrative Tools. WinXP: clickSTART-ControlPanel-Administrative Tools-Computer Management-DiskManagement-right clickthe flashdrive-selectFormat-selectquickformat WinVista& 7: clickSTART-ControlPanel- selectViewby:Large Icons-Administrative Tools-Computer Management-DiskManagement-right clickthe flashdrive-selectFormat-Performaquick format-OK.Ifthis does not work, don'trepeat,dothe third process. 3.Formatusing thesoftware,the HPUSBDisk StorageFormat Tool.Make the processquickformat.Ifthis does not work, don'trepeat,dothefourth. 4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system Win XP: double click the file cp006049.exe - select Install Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
2. Exit the Skype icon from the system tray(at the bottom right of the screen)
3. Ensure that "Show hidden files and folders" is switch is check & enabled (i). Start-> type "Run" & press Enter (ii). Type "control folders" & click OK (iii). Select the View tab & ensure the relevant entry is enabled
4. Locate the shared.xml file (i). Start-> type "Run" & Press Enter (ii). Type "%appdata%\skype" & click OK (iii). Delete the "shared.xml file" - (without quotes)
Restart Skype, a new shared.xml file will be created.
Works in my Gateway Netbook running a Win 7 Starter OS, Won't even install on my Dell N5010 running a Win 7 Home premium OS. BUT IT does work in Safe mode on the Dell laptop. Tried compatibility mode. Have no Idea why it won't install.
For the manual, I found the Smart thru 2 (not the Smart thru 4) Guide for the Z82 printer in the Lexmark website. It's a PDF file you can download. Just click on this link: http://www.lexmark.com/publications/pdfs/z82/smart.pdf . But I hope you'll find the needed information you are seeking.
I just fixed this problem for my computer. Try installing the scanner driver. You probably have the printer driver installed but the scanner driver is needed for Smarthru
