Question about Bose 3·2·1 II System
Bose 3-2-1 II Component help?
I have a bose 3-2-1 system (series ii) with component, composite, and (1) optical input. I'm wondering what the best setup is: I have a bluray player, with red white yellow out and an optical out, a directv receiver with the same, an xbox, and a tv. What setup would provide the best quality? Should I plug everything into the TV, and then use an optical cable to the tv? Or who should get the optical cable, the bluray or the receiver? I'm new tho this, help would be greatly appreciated!
Posted by adamah115 on
5 Related Answers
Anonymous
SOURCE: bose lifestyle v20 sound but no video
The problem turned out to be the TV itself. Somehow all the a/v and component cable inputs on the back of the TV got disabled. After finding then consulting the TV manual online (the TV is about 8 years old), we found there was a way to reset the TV to its original factory settings. Voila, the a/v and component cable inputs were enabled again, and everything worked correctly afterwards.
Posted on Oct 01, 2008
Derek Williamson
  • 40 Answers
SOURCE: No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Posted on Jun 19, 2009
airjoc
Rob Sinbad
  • 709 Answers
SOURCE: My Bose 321 series II is not responding to the
two things can be wrong. remote control or the reciever it self. 1st take the batterry out of the remote and unplug reciever for 1 minute or so. second put the batterry back in the remote and plug the reciever back in and see if any cahnges take place. make sure the battery is good and strong. if nothing take place accept TV and VCR is working from the remote than it would be your reciever IR sensor unit defective and seem to be a common problems with the IR sensor unit although bose will not acknowlege it. there is nothing you can do yourself without electronic background to fix it and trying to fix it your self might ruin the unit. I would contact the manufacture and ship it off to have it fix, after all the unit aint cheap and its worth it to get it fix. hope that help some .good luck
Posted on Jul 16, 2009
Anonymous
SOURCE: Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Posted on Oct 14, 2009
Anonymous
  • 8546 Answers
SOURCE: Integrated System (Bose Lifestyle) vs Component System
Better is a subjective term. Simpler vs complex is more accurate. I'd go for the separate components if conspicuity is NOT required and to allow unlimited future growth. Sub/sats have their place but nothing beats having full-range speakers alll around the room with some real horsepower to push them.
Posted on Dec 28, 2009
What is Bose 321 gsx video format?
The video formats are:
composite video (yellow phono/RCA) - 480i/576i [NTSC and PAL, respectively]
S-video video (black 4 pin din) - 480i/576i [NTSC and PAL, respectively]
Component (3x phono/RCA - Green Blue Red) - 480p NTSC only. Applies just to the DVD player output.
The 3-2-1 system has a couple of composite inputs, one s-video input, no (0) Component inputs. It has 1x composite output, 1x S-video output, 1x Component output.
The Bose system has very basic video handling capabilities. It will only pass through a signal in the same format as it is received. So, a composite signal in requires that the TV or display is hooked up with composite too. IOW, it won't up convert composite or S-video to component.
How do i hook-up a bose companion 3 series II system to an hdtv?
What type of connections does your tv have, hdmi, component? Match up the connection from the bose series 3 to your hdtv. I don't want to assume that your tv has hdmi, which would provide the best signal throughput & quality.
5helpful
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
I hooked up the cords exactly as picture and when in dvd input the picture is in black and white. I tried movie the yellow video chord to every single hole on the back of my tv and it doesnt go to color??...
If you tried the yellow composite cable "in every single hole" it wasn't exactly 'exactly' following the manual then, was it?
Are you using component cabels, too (red, green and blue). Mis-wiring them will give you B/W or other wierd visuals.
Your TV's inputs and what is selected by the TV's controls would determine which cables' input it display. You could prove whether the composite is the culprit by removing it while viewing the TV. If the picture goes away, THAT cable is carrying the video you're watching. Otherwise, maybe you need to select the component input and check the conenction of each wire while watching.
3helpful
2answers
Hooking up a Bose Lifestyle 30 II to an optical audio output
Actually, you can do this. Just get an optical to RCA converter.
This looks like a good one: http://www.amazon.com/Cables-Go-40019-Optical-Converter/dp/B0002GV876/ref=pd_cp_e_2
Cant get colour on my tv when playing dvds from my bose
check to make sure your plugged into the tv right the bose might only have composit out not component
Bose PS 3-2-1 II speaker exspansion
Unfortunately this is impossible on the 321 series II systems. There also is no audio output on the media center to send to another amp either. As you may know, the 2 speakers are actually 4 speakers. Each small speaker array has 2 drivers. The 2 on the outside will project rear-channel audio to the sides, so placement of these speakers is important. Honestly, adding speakers would not make this sound very good. If the sound isn't too great as is, make sure you're using digital audio cables (optical or coax) from any external sources like a cable box or Blu-ray player. (if you don't see a Dolby Digital 5.1, DTS 5.1 or PCM 2.0 read-out on front of the media center, you'll know it's not digital. DVDs the exception)
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
Bose 3·2·1 II System Logo
Top Bose Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
