Fisher and Paykel WL26CW1 Top Load Washer Logo
Don Rolfson Posted on Feb 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is the master overload breaker on a Fisher Paykel WL26CW1 washing machine?
Working fine with zero problems for six years! Power went out to house and now I can't get the washing machine to power up - even in an outlet we KNOW works. Please advise. Hoping I didn't blow the computer board but the machine is not seemingly getting any power at all.
keith jones
Level 3:
Master:
  • Fisher and P... Master 747 Answers
  • Posted on Mar 02, 2018
keith jones
Level 3:
Master:
Answers
747
Questions
Helped
314428
Points
1478
If it was left switch on at the wall when the power came on again it probably blew the computer board due a current surge
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Aug 03, 2009
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Anonymous
  • 30 Answers
  • Posted on Dec 02, 2009
SOURCE: i have trouble with my fisher and paykel washing
49. Cold Valve or Cold Valve & Hot Valve Faulty.
Testimonial: "thank you so much. now i understand what fault 49 is all about. however, can you help me fix the problem?"
luisa_sgro
  • 713 Answers
  • Posted on Jul 09, 2010
SOURCE: fisher & paykel washing machine (gw603-u) emptys while filling
Hi just read your posting.Now where is you machine draining to?Is it draining into the laundry sink or somewhere else?If it is draining into the laundry sink and not into a grey water hose then I am afraid it must be the green motor controller.This controller has the pressure switch as part of the circuit board.I think though it must be the fet that controls the power to your pump might be faulty.Are you in Australia as there are company's that will test your motor controller if you send it to them.Please reply with additional information and I can help you further.
icatci
  • 91 Answers
  • Posted on Sep 03, 2010
SOURCE: I have a fisher &
Hi dear.That's related to size error.When you replace the motor control module you need to set the machine wash capacity like:5Kg or 7.5Kg.To do that please follow the steps: Phase 1 to 6 Size Switch Error
The Display size switch setting does not match that stored in the memory.IW machines, Phase 5 and 6
To access Size Setting Mode. Push and hold the Fabric care button and then press the Power button to enter Size Setting mode. Select the correct size on the display by pushing the White button next to the correct size (phase 5) or using the Adjust button to highlight the right size (phase 6). Size setting is then achieved by pressing the Power button. Powering off will set the size into the memory. Check the size is set before starting a cycle.
I hope that helps.Thanks.
Anonymous
  • 252 Answers
  • Posted on May 07, 2011
SOURCE: Water sensing level not working on Fisher &
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
Fisher and paykel washer
Here is the service manual.
Start on page 35 to get to "Settings menu" and read thru to page 37 (scroll down to factory default).
Fisher and Paykel WL26CW1 Manual
Hope this helps to reset the machine.
1helpful
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Fisher and Pakel WL26CW1 code 246
i would say its one of the boards usually the main motorcontroller
My aquasmart fisher and paykel washing machine flashes up with error 235 about 2 mins after starting
Sounds like the 'lid lock' has shorted out. They're not completely waterproof and have seen pins completely blown out inside them. Should measure 73 ohms (or very close to it) across the terminals. Hope this helps.
1helpful
Fisher and paykel washing maching top loader screen does not light up?
If there is power to the machine and the display panel doesn't show any lights when 'power' is pressed there is a good chance that a fuse has failed in the motor controller module or that the module itself has failed.
Motor modules can fail when another component fails and overloads the module.
Modules should not be replaced without first checking the other electical components in the machine for resistance and/or continuity.
It's probably best to call an experienced tech who is familiar with F&P machines. I'm sorry not to help you fix the problem your self, but you can easily do more damage to the machine by not thoroughly checking and testing the machine. A repairer who is experienced won't replace a component without testing, and you won't have to pay for parts which might fail on installation..
Good luck....Nomess
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
