Widescreen line keeps moving
When i watch a DVD the widescreen line at the top of the screen keeps flickering. Ive tried differnt screen options like pal, and rgb but none work.
Posted by Stevi on
ernesto cuadra
    Top Expert:
  • 12,223 Answers
1) this a problem from power supply rise, or glitching
2) buffer, de-enfasis circuit, and Microcontroller chip.
3) servocomechanism, such sear, tracking, CLV,
You must go to the repair shop TV for fix it.to due the complex circuit inside.
God bless you
Posted on Jul 12, 2012
5 Related Answers
Anonymous
  • 155 Answers
SOURCE: Widescreen
Unfortunately, a cinema screen is even wider than a widescreen TV. Because of this (in order to keep the original aspect ratio), even with a widescreen TV you still end up with the black bars top and bottom.
Check the aspect ratio of the DVD (Should be printed on the back of the case somewhere).
Unless it says 1.85:1 or 16:9 Anamorphic, you will get the black bars. (Many films on DVD are 2.35:1 or even wider!)
Have you got any different picture modes on your TV. I've got a Toshiba and it has something called 'cinema mode' which does eliminate the bars. Unfortunately it does it by zooming in on the picture slightly, so you loose a bit off the side of the picture and the image does get a little grainier.
Hope this helps.
Matt
Posted on Feb 29, 2008
Anonymous
  • 273 Answers
SOURCE: Transfer from Widescreen camcorder through S video results in Full Screen instead of Widescreen
have you set the dvd to widescreen? i know some change automatically when there is widescreen input but some need to be changed manually. This should be in system settings. hope this helps
Posted on May 19, 2009
Anonymous
  • 12 Answers
SOURCE: On our SOny BDP-S360 DVD player, when we watch
you might have a loss connection?
what kind of cable are you using ?
hdmi / component / composite?
unplug the power cord to the ac outlet for 30 secs. and plug it in back. this is to refresh the unit.
turn on fan on the configuration of the unit ...
please read the operating manual ...
Posted on Jan 06, 2010
fs8228
  • 127 Answers
SOURCE: How to Change NTSC/Pal ?
press the button again
or try taking out the
DVD
Posted on Jan 10, 2010
Michael Otto
  • 16 Answers
SOURCE: Picture skips, flickers, cannot watch. Was working
Some of the common causes of this issue can be found below.
  1. Take the disc out of the unit.
    • Verify that the disc is clean and not scratched.
    • If disc does not appear to be clean wipe it with a soft lint free
      cloth.
  2. Try other discs. Verify that they are clean and not scratched.
  3. Unplug the unit for 2-3 minutes.
  4. After plugging the unit back in, try multiple discs to see if they
    work.
  5. If problems persist I would have to say there is something over heating and it cant be fixed or is not worth the cost of fixing
Posted on Feb 28, 2011
The picture is crunched like if you were watching a letterbox movie.(with the black at the top an bottom of the screen how do i correct this
Black on top of bottom is widescreen.. Some dvd's are made in only widescreen. Usually you have to buy a full screen disc to cover the entire screen or change to format to 16:9 or 6:9 or whatever it handles/
You may see the black on top and bottom, it is annoying at first, but the picture is so much wider and you can actually see more on a widescreen
Dec 01, 2009 | Panasonic PV-DM2792 Triple Play 27 in....
Yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
I do not believe your problem is with the DVD player. It most likely is with your TV. What happens alot is the picture on a TV is set to a different aspect ratio(ie:4:3,16:9). and sometimes it stretches or zooms the picture, allowing part to be cut off the edge of the screen. This aspect ratio problem can have two causes now that I think of it. The TV or the DVD player. To determine and fix, follow these steps.
PART 1-determining problem-
1 Watch regular TV for awhile and get some infomercials(yes, you have to watch Billy Mayes) on the bottom and edges of the screen, are there words and 800 numbers cut off, if so, your problem is with the TV and skip now to part 2(not step 2)
2 If you can see the whole number and everything , determine if your TV auto adjusts or not. Switch to your DVD player and see if the screens seems to move(shrink or enlarge). If it does shrink or enlarge, your problem is with the DVD player and you can now proceed to part 2.
PART 2-solving problem-
1 By now, you have determined whether the problem is with your tv or dvd player. From this point on "it, it's will refer to whichever has the problem
2 Go into it's menu
3 search for "picture" "video" or "setup"
4 Search for "aspect ratio" or anything containing "4:3" "16:9" or the words "stretch" "zoom" or "widescreen"
5 Set to 4:3 (sometimes 4:3 has multiple options such as stretch, zoom, and normal, if so, select normal)
6 ***OPTIONAL*** If you want widescreen, select 16:9(again if multiple choices, choose normal)
7 Insert or select a DVD and test your subtitles
If this does not work, please post a comment and I will help you further.
Hope this helps and please don't forget to rate
-Chris
May 03, 2009 | Yamaha DV-C6770 Multi-disc DVD Player
DVD WS does not display right on Samsung 40'' HD 1080P LCD TV
Check the aspect ratio of your widescreen DVD. I'll assume that your flat panel TV is widescreen, which would mean it has a ratio of 16:9. Some movies are even wider than that (i.e. 2.35:1), so it would be normal for you to see black bars at the top and bottom. Look for a WS DVD described as 16:9 (usually shown on bottom on back). This should fill your TV screen and not distort the image. If you still see the black bars, you will need to check your DVD menu settings for widescreen aspect, and supply more info on the DVD player and TV.
Nov 30, 2008 | Televison & Video
Now using an hdmi to dvi cable - screen size has reduced
Your digital box should have aspect settings as well. When watching HD TV and or movies there is a possibility to get the black bars on top and bottom. It all depends on the ratio it was filmed in.
Nov 18, 2008 | Philips Televison & Video
When watching any DVD's with my Samsung HT Q100 DVD player there is a black band at the top and bottom of my Sharp 42 inch LCD screen- what settings do I need to change to get these removed?
Normally dvd's have a widescreen and full screen option somewhere in the settings menu. Try to find these two options and just switch to Full screen.
Apr 20, 2008 | Televison & Video
Widescreen cinema mode
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
Apr 03, 2008 | Televison & Video
Widescreen
Hope this helps.
Matt
Feb 29, 2008 | Philips DVP3020 DVD Player
High Definition Channels leave bar on top and bottom
More then likely it has to do with the aspect ratio of what you're trying to watch. Most DVD's are in widescreen format (2.40 to 1) like you would see in a theater but an HD tv is a 16 by 9 format or 1.85 to 1. Look at the DVD case and see. Also some HD shows are in widescreen so you'll get the same thing. You're only option to fill the screen is get movies in 1.85 to 1 or use your zoom functions however these do tend to distort the picture.
Feb 17, 2008 | LG 50PX4DR 50 in. Plasma TV
Shows as widescreen instead of normal view
try using the tv remote to change the screen size and keep changing it until you find the correct size
Oct 21, 2007 | Pioneer DV-525
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
