My email is [email protected] Monitor will not turn on!
SOURCE: Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
SOURCE: Acer 20" LCD AL2017 does not give a picture @ all.
You can look on eBay for BACKLIGHT FLUORESCENT BULB for your model.
They're around $20.00.
SOURCE: Monitor comes up shows "acer" then says no signal and goes black
The interface between the monitor and the cable might need replacement. Please check it.
SOURCE: Acer AL2017 Monitor
you will need 3 or 4 ( forget now) 220 uf 25 volt and two 1000 uf 25 volt .... just finished putting this one back together and it's great.
SOURCE: Monitor colors are not displaying correctly
Hi, At the worst it is a blown monitor, but have hope. 1st try a new or known good lead, between monitor and PC. 2nd put monitor with own lead on good PC. if 1st works = result. if 2nd and monitor is same, suspect monitor, however, if 2nd works ok on other PC, then look at ur vid card. Either way, this test sequence should save you some $. Be lucky.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
