State: warning
home network only: your unit is connected to the home network but not the internet. please check your router settings or contact your isp or router manufacturer
my computer is connected to the internet with full bars and i am not sure why my blu ray isn't getting connection.
Make sure that the modem/router is up and running. Turn the player off and unplug from wall socket for 1 minute. Then plug in and switch on. This might help.
Check the cable going from the BD to the router. The player may have lost it's IP address...unplug it and wait about 5 minutes then plug it back into the wall.
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
Your mobile has a built it Wireless Fidelity or WI-FI module enabling to catch ata over wireless networks.
By turning ON your wi-fi, it will search wireless network along the nearest location of yours. Once you found a network(s), just open it and wait until established and connected,but some authenticating connection never allows you to connect because it needs a password encryption.so you won't able to patch the network if you do not know the code.
If you have a broadband installed at home, you need a wireless router that can supply internet connection using your mobile phone via wi-fi,just easily series the broadband connection thru a wireless router and also add encryption like WEP key to ensure you are the only one catching the connection.
please state your broadband if any so that i can guide you the procedure in installing your wireless router connection.
If you have some questions, don't hesitate to reply cause i will glad accomodate any comments.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of thePLAY STATION
NETWORK SETTINGS ==> INTERNET CONNECTION SETTINGS ==> WIRELESS SETTINGS==> If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==> select EASY ==> select WIRELESS==> SCAN ==> you will see your SSID ( wireless network name)==> select the security settings ( router wireless settings)==> enter the KEY ==> select the IP address settings EASY ==> save your settings ==> Test the connection .
check that the network its network drivers are fully installed to check it, right click on my computer icon, then hardware, then device manager, any yellow spot or question mark you see from the device manager means that there is a driver missing.
At last, I have finally resolved the issue, sometimes the solution is so somple that you totally miss the solution. It was as simple as the Windows Firewall ( switch it on ), I have a Mcafee security center protecting my network and it wouldn't let me connect with additional protection. Also, I entered the wrong mac address on the routers (access control) settings. I'm now on the internet. Obviously I have to big up Mcafee for excellent security controls. So if anybody else ever has the same problem follow these simple steps.
Check all of the settings that I described in the original question
Make sure Firwall settings are correct (& active).
Check your routers homepage ( access control truly works).
Make sure you you enter the correct MAC address (use the MAC address of the wireless network adapter, that's what connect you to a network) i.e. 00-01-a2-11-22
You need to reconfigure the router. The power outage probably resetted the router to it's default settings. In the default state the router doesn't have any wireless security; hence the "unsecured network" warning from your PC.
Connect your PC or a laptop with a cable to the router, surf to (http://192.168.1.1 or https://192.168.1.1 - ignoring any security warning); which is the configuration interface of the router and follow instructions in the manual.
When you have a Linksys configuration CD, you can simply run the "Easy configuration" setup after connecting your PC with a cable to the router.
Plainly put you just have to configure the router just like when you first used it.
Choose a convenient location to
begin installing your router such as an open floor space or table. This
does not need to be the permanent location of the device. Particularly
for wireless routers, you may find it necessary to re-position the unit after installing
it as the cables / signals may not reach all areas needed. At the
beginning, its better to choose a location where it's easiest to work
with the router and worry about final placement later.
Plug in the router's electrical power source, then turn on the router by pushing the power button.
(Optional) Connect your Internet modem to the router. Most network modems connect via an Ethernet cable but USB
connections are becoming increasingly common. The cable plugs into the
router jack named "WAN" or "uplink" or "Internet." After connecting the
cable, be sure to power cycle (turn off and turn back on) the modem to
ensure the router recognizes it.
Connect one computer to the router.
Even if the router is a wireless model, connect this first computer to
the router via a network cable. Using a cable during router
installation ensures the maximum reliability of the equipment. Once a
wireless router installation is complete, the computer can be changed
over to a wireless connection if desired.
Open the router's administration tool.
From the computer connected to the router, first open your Web browser.
Then enter the router's address for network administration in the Web
address field and hit return to reach the router's home page.
Many
routers are reached by either the Web address "http://192.168.1.1" or
"http://192.168.0.1" Consult your router's documentation to determine
the exact address for your model. Note that you do not need a working
Internet connection for this step.
Log in to the router.
The router's home page will ask you for a username and password. Both
are provided in the router's documentation. You should change the
router's password for security reasons, but do this after the
installation is complete to avoid unnecessary complications during the
basic setup.
If you want your router to connect to the Internet, you must enter Internet connection information into that section of the router's configuration (exact location varies). If using DSL Internet, you may need to enter the PPPoE username and password. Likewise, if you have been issued a static IP address
by your provider (you would need to have requested it), the static IP
fields (including network mask and gateway) given to you by the
provider must also must be set in the router.
If you were using a primary computer or an older network router to connect to the Internet, your provider may require you to update the MAC address of the router with the MAC address of the device you were using previously. Read How to Change a MAC Address for a detailed description of this process.
If this is a wireless router, change the network name (often called SSID).
While the router comes to you with a network name set at the factory,
you will never want to use this name on your network. Read How to Change the Router SSID for detailed instructions.
Verify the network connection is working
between your one computer and the router. To do this, you must
confirmed that the computer has received IP address information from
the router. See How to Find IP Addresses for a description of this process.
(If applicable) Verify your one computer can connect to the Internet properly. Open your Web browser and visit a few Internet sites such as http://compnetworking.about.com/.
Connect additional computers to the router as needed. If connecting wirelessly, ensure the network name (SSID) of each is computer matches that of the router.
Finally, configure additional network security features as desired to guard your systems against Internet attackers. These WiFi Home Network Security Tips offer a good checklist to follow.
Tips:
When
connecting devices with network cables, be sure each end of the cable
connects tightly. Loose cables are one of the most common sources of
network setup problems.
What You Need:
A network router (wireless or wired)
Network adapters installed on all devices to be connected to the router
A working Internet modem (optional)
A Web browser installed at least one computer in the network
Please let me know if you need any further help and I would be glad to assist.
