I need a replacement glass turntable for my Emerson MW8991SB microwave oven. Serial#61202068 MM
Go to www.ebay.com Type make and model of microwave oven, refine search to plate.
SOURCE: Emerson microwave Glass turntable replacement
check with www.microwaveglasstrays.com
toll free 1-877-894-0035
SOURCE: Emerson 900 Watt Microwave MW8991SB glass
For more help from
Emerson visit
here or get
help using your appliance at 1-800-898-9020. Get help locating an
authorized servicer or parts at 1-800-695-0098.
Emerson parts are
distributed by Fox
International
and their number is 800-321-6993. Or you might try
e-mailing [email protected]
Many Emerson microwave
owner's manuals are available for free download here.
Even though
yours may not be there, there might be one close enough to help you .
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Replacement of the
turntable motor should be carried out by a qualified appliance repair
service.
But here is a basic methos if you are
mechanically minded and have electrical safety knowledge.
The motor assembly is fixed to the base
of the oven usually with two screws and access is obtained usually by
removing the inspection plate directly beneath the motor. It is
usally a plug in synchronus motor that revolves at a few revs per
minute but the plastic cogs in the motors gear box fail and the motor
assembly must be replaced. They are fairly inexpensive and obtainable
usually from a domestic appliance repair shop.
If you feel
confident, disconnect it from the mains power, remove anything in the
cavity and turn it upside down if it is a tabletop model, a little
more complicated if it is built in!
Remove the inspection plate,
sometimes it must be cut out with sharp cutters, and disconnect the
motor. Remove the motor and go and get a new one. Fit the new motor
and fit the inspection cover back on the base by turning it to fit
and using an extra screw fix it then put the microwave back in its
position. Plug it back in, with the turntable and plate. Put a cup of
water on the plate inside of the oven and heat for 20 seconds to
check the plate goes round.
Hope this helps.
