Deadbolt opens when lock button is pushed and locks when code is entered. Have taken batteries out and reinstalled several times with no success.
"I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?"
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
These instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
These locks are made to work on a door which, when you stand outside and face it, has its hinges on either the left-hand or right-hand side of the door (= door "handedness").
The jumper controls that for the appropriate installation. Yours is set wrong!
SOURCE: My Kwikset Electronic Deadbolt is
Here's the installation instruction sheet for the 907-15. Pay particular attention to page 6, where it mentions the left or right-hand installation of the lock, and the need to move the jumper to change the function accordingly.
http://s7d5.scene7.com/is/content/BDHHI/40486-02
