HP 7410 Scanner mirror dirty
you can go tru this extract ON HOW TO FIX IT
clean the glass
Dirty glass, from fingerprints, smudges, hair, and so on, slows down
performance and affects the accuracy of special features such as Fit to Page and
Copy.
1 Turn off the unit, unplug the power cord, and raise the lid.
2 Clean the glass with a soft cloth or sponge slightly moistened with a
nonabrasive glass cleaner.
Caution! Do not use abrasives, acetone, benzene, or carbon
tetrachloride on the glass; these can damage it. Do not place
liquids directly on the glass. They may seep under it and damage
the unit.
3 Dry the glass with a chamois or cellulose sponge to prevent spotting.
clean the lid backing
Minor debris can accumulate on the white document-backing located
underneath the unit’s lid.
2 Clean the white document-backing with a soft cloth or sponge slightly
moistened with a mild soap and warm water.
3 Wash the backing gently to loosen debris; do not scrub the backing.
4 Dry the backing with a chamois or soft cloth.
Caution! Do not use paper-based wipes as these may scratch the
backing.
5 If this does not clean the backing well enough, repeat the previous steps
using isopropyl (rubbing) alcohol, and wipe the backing thoroughly with a
damp cloth to remove any residual alcohol.
clean the exterior
Use a soft, damp, lint-free cloth to wipe dust, smudges, and stains off the case.
The interior of the unit does not require cleaning. Keep fluids away from the
interior of the unit as well as the front panel.
