SOURCE: Hayward 1 hp super Pump just hums then shuts off.
turn shaft manually wiyh pliers if somthing is stuck in propeller this should clear it
SOURCE: new hayward 1 HP super pump runs 1 or 2 seconds,
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
SOURCE: Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
SOURCE: I am replacing my Hayward 1 HP superpump. The old
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Testimonial: "Very good. Thank you very very much."
SOURCE: I have a Hayward 1 HP pool pump. I have to
hi ...the two yellow go on one side of the cap and the red /white go on the other.. like two on the negative side of a battery and one on the pos .. your pool pump repair guy longwood fl
