Ccb 235 what other details?
YOUR FRIGE BECAME NOISY? HAVE YOU CLEANED OUT THE FINS LOCATED EITHER UNDER THE FRONT OF YOUR FRIDGE, OR AROUND BACK BEHIND A CARDBOARD PANEL? DUST LINT ANIMAL HAIR AND OTHER DEBRIS CAN AND DO GET SUCKED UP BY A SMALL FAN THAT IS INTENDED TO REMOVE THE HEAT FROM THE COMPRESSOR AND THE REFRIGERANTE CYCLING THROUGH THE CONDENSER ON ITS WAY TO THE EVAPORATOR TO CHILL THE INSIDE OF THE FRIDGE DOWN. IF ENOUGH OF THIS CONDENSER IS BLOCKED FOR A LONG ENOUGH PERIOD IT CAN CAUSE THE COMPRESSORS VALVES TO BECOME WORN OUT PREMATURELY. YOU MAY ALSO HAVE A BIT OF SOMETHING IN THE FAN BLADE OR THE FAN MOTOR MAY BE BAD. WAS THE NOISE INSIDE OF THE FRIDGE? IT COULD BE THE EVAPORATOR FAN HAS A PROBLEM. IF ICE BUILDS UP IN SIDE OF THE FRIDGE WHERE THE EVAP FAN THAT BLOWS THE COLD AIR AROUND THE COMPARTMENT HAS NOT BEEN CLEARED OF THE ICE THAT IS COLLECTED ON IT BY ANOTHER DEVICE KNOWN AS A DEFROST TIMER IT MAY HAVE CAUED IT TO HIT THIS BUILD UP ON THE EVAPORATOR. IF THE NOISE WAS NOT INSIDE THEN DO NOT LOOK AT THIS, IT IS ONE OF THE AFORE MENTIONED ITEMS. YOU CAN CLEAN MOST OF THE DUST/HAIR ACCUMMULATIONS OUT WITH A VACCUMM AND EXTENSION WAND. IF THOSE ARE NOT HANDY A AIR COMPRESSOR OR A SHOPVAC WITH EITHER THE SUCTION SIDE OR THE BLOWER SIDE WILL ALSO WORK IF A EXTENSION WAND AND NARROW WAND ARE AROUND. IF U ELECT TO USE A AIR COMPRESSOR OR BLOW IT OUT WITH A SHOPVAC DO IT OUTSIDE HA HA.
For this problem, its indicating towards
problem with damper assembly.----------
The working procedure of this unit is as
follows: --- The compressor starts then it cools the freezer section. When the
freezer reaches its cooling level the defrost cycle starts functioning. In this
cycle the fan in the freezer section starts running and the cool air in the
freezer section is passed to the fridge section and the fridge
section gets cold. The air from freezer to refrigerator passes from the
section, in that section the damper is located. ----------- The damper is
operated by a motor.Its a complete damper assembly with motor included in
it.--The damper has door.Which closes and open with the help of motor.In your
case the damper door is remained open, its not closing.Due to this the cool air
from freezer section is running in to fridge section non-stop.Due to this the
vegetables and other food in the bottom drawer freezing.--------- In this
problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
You can get
required parts from online sites like: --- www.repairclinic.com
or from searspartsdirect online site. ----------- This should help.
Thanks.Helpmech.
I don't know what else to add except that it had become very noisy prior to packing up,There has been no leakage of water
