I have adjusted/played with all manual controls from the front and back panels. The front vents work great.
The site listed here for info is not a safe site, red flags went up on my virus program.
1) test the switch for dirty, open or defective use the VOM, fuse defective, or open or bad contact, tight any wires connector for good contact, motor defective or loose wire connector.
I can recommend go to www.autoelectronico.com+ links this web is spanish but you can translate with your web browser . However i can recommend you by powerful information update complete for any models cars, You can download diagrams in PDF format. Try it and fix it.
God bless you
SOURCE: 2004 Ford Expedition rear floor cool/heat
Item
Part Number
Description
Air inlet door
Temperature blend door
Headliner airflow
Auxiliary mode door
5
Floor airflow
6
18476
Heater core
7
19860
Evaporator core
8
19805
Blower motor
The auxiliary A/C and heating system has the following features:
I would say the auxiliary mode door (#4) electric motor is not wokring.
Auxiliary Blend Door Actuator —Air Distribution
Removal and Installation
SOURCE: 2003 Ford Explorer. A/c blows cold, but not from front of vents
I have the 03 Expy with continuous rear air unit "clicking" or more accurately flapping of the air damper while the plastic gears in the 2L2H-19E616-AA grind away into toothlessness. Ford designed this unit to find the end of travel by jamming the motor to a stop and monitoring the current to determine when to stop applying voltage. That would probably be fine if the gears were designed to handle the jammed torque or the motor did not slip out of groove and continue turning and cracking the plastic gears.
There are two white colored boxes, one is for the temp plenum door, the other the upper/lower air flow. To be sure, do what I did, turn on the ignition, rear ac/heat and listen for the obnoxious click/thump as you move the temp control from full heat to full cool, you will know which part. Disconnect the electrical connector, four bolts and it is out!
Go to your dealer, part should be about $60 or less, look on line, lots of dealers sell for this or less on internet.
SOURCE: climate control system only blow air out defrost vent
there is a good chance that you blend air door is stuck closed over your heater core and therefore not allowing the heat to flow, also your door that opens and close your direction of flow from the floor ,das,vent and defrost.your going to have to remove the lower cowling of the dash on the passenger side analso some of the center dash to actually check to see if the cable,servo motors. are acuating the doors.the issue could be just a stuck door or a misaligned cable or that it came off. that falls under the mechanical side of probabilities. electrical would most likely be a faulty selector switch or a servo motor
SOURCE: 2004 Ford Expedition XLT, front blend door actuator
Hope I was avle to help, glad you up and going.
SOURCE: A/c Vents in front are not blowing from the panel
check or replace the blower relay, located under the dash panel RH side.
When I turn on the heat in my 2004 mazda mpv the front air vents blow heat but the rear air vents are blowing cold. I have adjusted every setting is there something I am overlooking.
