Question about Fisher and Paykel Washing Machines
Machine stopping at spin cycle with leds 3,5 &8 flashing
That is fault code 41
41. (00101001) Temperature Sensor Fault (Thermistor)
The temperature sensor is measuring temperatures above 110oC. The fault is probably
due to a short circuit in the sensor line. This fault is only applicable in the GW models.
Primary Source: Thermistor.
Action: 1) Check the connection from the thermistor the Motor Control
Module
2) Check the resistance of the thermistor. It should read 12.5k ohms
at 20oC. Replace if faulty.
3) Replace the Motor Control Module.
Posted on Dec 22, 2013
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
SOURCE: Fisher & Paykel GW703 wont stop!
It sounds like your machine has been programmed to automatically run through the various cycles continuously. Most likely in error.
Posted on Mar 08, 2008
SOURCE: INDESIT WIXXL 146 washing machine ( please help
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 18, 2010
