Hi, please can you help. my phone went off and wont come back on again. when i try to put it on it just shows a battery with a red cross on it
SOURCE: blackberry storm wont turn on
it sounds like *********** Borad - or The Circuit Borad on the Phone might be damaged.
Did you drop it?
SOURCE: screen shows battery with a red line through it
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
try to connect with Pc suite and update firmware or set factory reset via pc suite,this will solve.Best of Luck.
SOURCE: My Blackberry 9530 shows that
your Blackberry 9530 have hardware problem it has charging jumper problem repair it from any repairing shop
SOURCE: hi, i have a blackberry
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
