I have found the driver side exhaust manifold was cracked and leaking and I am having replaced. I actually drove the car for a few months not knowing what the problem was other than more engine seemed to be running louder than usual and there was a ticking noise. I'd like to know if this leak can also cause performance issues as well because since this problem started, it seems that the vehicle has had less boost than it should and I know it has been using more fuel. What can a long term leak from the Ex Manifold do to the performance of a car?
SOURCE: 96' toyota corolla Exhaust Manifold Keeps Cracking
Sounds weird that this problem keep occurring over and over. Does it crack in the same spot every time?
Only two things I can think of that would cause this problem.
1. Extensive over heating, I've seen a exhaust manifold get glowing red hot because of a bad oxygen sensor.
2. Excessive Vibration. The whole exhaust line to the back of the car is moving around too much or too stiff. The exhaust line needs to move around enough to take the movement/vibration of the engine. I would check out for bad motor mounts and worn out exhaust pipe mounts.
SOURCE: exhaust manifold has a leak planning on drive
All possible damage to your car aside, you could potentially fill the car with exhaust gas. Best case you'll get woozy or a headache. Worst case you could pass out while driving. It is not a good idea.
SOURCE: I've got a 2002 Escape, and all of a sudden when
ok exhaust smells tend to intensify in cold weather. your vehicle is using more fuel the colder it gets. once the engine warms up does the smell go away? if it does, then i wouldn't worry.
SOURCE: running rich. No power. 5.2 v8
93 Jeep grand cheorkee 5.2 L engine, no power is getting yo fuel pump
SOURCE: My 2001 Ford Focus had the engine light on and the
have it scanned at a real shop that will save you alot of money from back yard mechanics... i have had the problem of the coil plug wire connecting plug
