Question about HP ProLiant ML370 G4 Server
Base system device driver for hp proliant ml370 g4
3 Related Answers
Anonymous
  • 61 Answers
SOURCE: hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Posted on Oct 25, 2008
info2u
Nouveau IT, LLC
  • 596 Answers
SOURCE: HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
Posted on May 28, 2010
Anonymous
  • 5 Answers
SOURCE: my HP Proliant ML370 G4
dear erwin,
as per your writing the server raid has broken .. its may be a problem with a hard disk , first you have to check the hard disk state . to do that you should enter into raid bios . don't try to something on that , just see the status of logical drive then which are the disks includes on that raid
in you post also it may give the details of failed disk ids
then you may have problem with your batt. unit , for that please do the above steps first then back with that...
Posted on Aug 11, 2010
My hp ml370 g4 startup and the health led is green but when the dignostic utility appers on screen the health led become red and the keyboard not responding help plzzzzzzzzzzzzz
Open the case and turn on. There should be a corresponding led lit inside. That, or you could run Insight Manager. It will tell you exact details.
Feb 28, 2013 | HP ProLiant ML370 G4 Server
Hp proliant ml370 G6 ethernet controller, base system device and IPMI interface not configured properly
Correct it or disable it. It's just a warning. Check SNMP setting for traps.
Besides you should be using the Smart Start with Insight Manager on HP servers.
Oct 20, 2012 | HP ProLiant ML370 G6 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
Startup problem
Assuming all appears normal (LED's etc) I would suggest you could have a Processor or VRM issue. Drop the machine to a single processor /VRM and see if that helps. Another possibility is a system board issue
May 27, 2009 | HP ProLiant ML370 G4 Server
How can i get the installation cds for a 370 G4 server ..PEPPER
What installation CDs do you need? System or preconfigured O/S stuff? Try contacting HP directly or cruising their support site or forums for assistance.
May 11, 2009 | HP ProLiant ML370 G4 Server
Hp proliant ml370 g4 rebooting problem
Jul 16, 2008 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G4 Server Logo
187 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
