Canon LC-3175 Laser Fax Logo
Question about Canon LC-3175 Laser Fax
Canon 3175 check paper size error - Canon LC-3175 Laser Fax
2 Related Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: Paper Size
double check the menu section is it set for Letter?
check the tray do you have Letter paper in it, are the guides set correctly?
Posted on Aug 19, 2008
Anonymous
  • 739 Answers
SOURCE: The fax received is always
Hi..
r u sure yr type printer/facsimiles model true?
refer to your true model first..
Posted on Apr 18, 2011
2answers
We have a Canon Image Runner 3235 that is hooked up to a network. Every time we try to send more than one document to print off we get the error message to load paper and it doesn't need any paper. ...
if the message add paper related with specific paper size i.e. add A4 paper in drawer, first you need to check is the paper senzor in drawer set to correct paper size - it is blue circle with markins of paper size. Second thing under printer driver properties on PC check if the correct paper size is choosen.
Hope that helps!
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
1helpful
2answers
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
1helpful
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
3helpful
2answers
2helpful
3answers
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Canon Laser Class 3175 facsimile, incoming faxes are being saved in memory, will not print. Cannot clear error message "check paper size".
The problem is that you have a fax saved in memory that is the wrong size for the paper you have in the drawer. Probably it is a legal size, whereas you have letter size in the drawer.Just place some legal size paper in the by-pass tray to print.
4helpful
3answers
Paper sizing error
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
old marine
old marine
Marvin
Marvin
