Hi! Thanks for your help. At a garage sale, I bought the Sanyo DWM-2500 DVD Home Theater System. As you're viewing the rear panel (where everything gets plugged in), there is a square slot on the far left that is supposed to have something there to allow AM radio reception. Radio Shack didn't have anything, don't know where to go to get this. Any recommendations on the part or where to get it?
SOURCE: Dwm-3900 wont play dvd's
Because you have limited knowledge of your products history, first ensure that your Country Code is set correctly. Using your remote, access your User Menu/Setup > Country Code > U S > Memory > Setup. I am assuming that you are in the US, and are trying to view Region 1 DVD's. Please update for further instructions if the above doesn't solve your problem....good luck.
SOURCE: Sanyo DWM-3500 5.1 Ch. Home Theater System
yes get a hold of them at -1-(507)263-7900
tell them make and what part you need thank you for useing fixya
SOURCE: Hi, I want to know if
In stereo, yes. At a minimum your PC should have a headphone output and/or a rear-panel stereo speaker output (usually 1/8" green), which is essentially the same. Get into the audio controls and set whichever you use to be Large Stereo speakers.
Get an adapter for the 1/8"-stereo-to-RCA-cable pair and attach it to the only analog audio input on the Sanyo.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sanyo-DWM-3500-Home-Theater-Systems-manual/id/311dj897/t/2/
Need help? Call Sanyo 1-800-813-3435
