Yes i was browsing my storage particularly my Music then sudenly my phone vibrates twice.then hanged.then i turned it off when i opened it again i noticed that My storage disappeared.pls help i have a lot of important files in it.si i need to retrieve them pls help me how
SOURCE: my samsung sgh-x830 does not turn on
this has happened to my daughter today 19:05:08 did anyone find an answer or how did u get it fixed ???? :(
SOURCE: Samsung Juke not able to put music in!! Need help!!
I had the same problem. It happened when I deleted all the songs off. Here's what I did:
I took out the battery (leave it out for like a minute)
Turned on the phone
Plugged the USB into the phone....then into the computer
I then got to pop up to sync/view files
Then I unplugged it and was able to go to my music
SOURCE: samsung sgh-d780 - cant transfer files from pc to phone
Try this: unconnect the phone, restart it and make the change (the phone being unconnected to the USB). It worked for me...
SOURCE: Brand New Samsung Omnia Out of Memory
I found this fix on another website. After numerous calls to verizon-they had no clue-and hours of trying to figure things out I found and tried this fix and it worked!
"I have a Samsung Omnia on VZW network. I was getting the "Memory Critically Low" error too. So, I opened File Explorer and did some searching for files that could be removed etc. I found an entire cache of files here: My Device: Program Files: VZAppZone:Temp:Temp
I deleted these files using a mass delete: Menu:Edit:Select All: Menu:Delete With no ill effects as of yet.
I spent the better part of an hour testing every application on the phone, opening contacts, etc. I haven't noticed anything wrong.
Doing this freed up almost 35mb of storage!!!!! "
I had the same results. This finally solved my mem problems-no more pop up critical me low box!! It freed up over 1/2 the avail memory.
Another tip is to clear out your browsers cache files
SOURCE: data saving problem in samsung omnia i900.
i have problem with samsung omnia. i can't receive data via bluetooth. i turn on bluetooth and find device but i can't receive data from other phones or computers... please help
