Question about Dometic Refrigerators
Can you recharge a DOMETIC RM2310 Refrigerator
Posted by bob ruppel on
  • bob ruppel Jul 10, 2012
    if it can be what kind of freon
  • Arcticold Refrigeration Ltd
    The RV refrigerators are for the most part Absorption style refrigerators that use Ammonia as a refrigerant. They can not be simply recharged, but fortunately you can purchase replacement cooling units for them. check out www.arcticold.com
ALI ONE
    Sergeant:
  • 195 Answers
ONLY IF IT'S NORMAL REFRIGERANT.IF IT'S AMONIA THEN NO.BUT IF ITS AMONIA FRIDGE TURN IT UPSIDE DOWN FOR 24/48 HOURS AND THEN BACK AGAIN AND TRY .U MIGHT GET LUCKY.GOOD LUCK.(ALL OFF BEFORE TURNING IT OK?)GOOD LUCK ALI
Posted on Jul 09, 2012
3 Related Answers
Anonymous
  • 13 Answers
SOURCE: Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Posted on Aug 17, 2009
Anonymous
  • 51 Answers
SOURCE: dometic refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Posted on Sep 07, 2008
mexifin
  • 24 Answers
SOURCE: dometic rm2310 i turned on
This is very serious, You need two people to find the leak or take it to qualified lp technician.
Posted on Sep 28, 2010
Dometic rm2310 i turned on the lp. after 10 min over taken with gas fumes
Sep 27, 2010 | Dometic RM2652 Refrigerator
Has leaked out all 'gas' from the cannister to the down tube. Can this be repaired and recharged?
If by 'gas' you mean refrigerant, then yes, it can be recharged. However, in order to legally recharge a refrigeration unit with refrigerant you need a special certification from the EPA. I recommend you get a certified technician to take a look at your refrigerator
Mar 23, 2010 | Dometic RM2620 Refrigerator
Aug 17, 2009 | Refrigerators
Refrigerators Logo
1,886 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
