Question about Weiser Lock POWERBOLT ELEC DEADBOLT
Deleting Codes on a Weiser powerbolt.
When I program a new code into our Weiser Powerbolt, the old codes do not get cancelled. How do I cancel all old security codes and start fresh?
Posted by Clark Rasmussen on
Coaltowner
  • 963 Answers
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Posted on Jul 11, 2012
3 Related Answers
Anonymous
  • 26 Answers
SOURCE: my powerbolt keeps beeping short beeps and then
dead batteries
Posted on Aug 18, 2009
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: How do I reprogram the
  • Remove the inner cover plate from the lock.
  • Locate the small round reset button near the left side of the circuit board (Red or Black).
  • To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
best of luck.
Posted on Aug 02, 2010
Coaltowner
  • 963 Answers
SOURCE: How do I clear (erase) all codes from my Weiser
How do I change the access code (and delete my old code) on my Powerbolt 1000?
The steps below are to change your access code to a new code. This will also remove any previous codes stored in the Powerbolt's memory.
  1. Manually put the bolt in the extended (lock) position. Press the PROGRAM button once, enter your new 4 - 8 digit code and then press the LOCK button.
  2. Press the PROGRAM button twice, enter the same new code and then press the LOCK button once.
  3. Press the PROGRAM button three times, enter the same new code and then press LOCK once.
If your old code still remains in the unit, you will need to perform a hard reset of the unit. To perform a hard reset of the unit, remove all four batteries and leave them out for 1 hour. After the hour has passed, you may re-enter the batteries.
United States of America Customer Service Contact Information
Call Us Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Good luck, Elizabeth!
Posted on Jul 26, 2011
Reset new codes and old existing codes won't erase,the original code from last year still works, even after installing 2 new codes
Here's the link to the online instructions:
http://www.weiserlock.com/PDFS/instructions/Electronics/Powerbolt.pdf
Programming instructions are on page 6. Notice that allowing too much time between inputs will be a problem.
If you cannot successfully override your existing codes, contact Weiserlock Customer service:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
A note about PDF files: You will need adobe Reader or equivalent installed if you are unable to view the instructions. http://get.adobe.com/reader/
Nov 03, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
We bought a house with this lock and don't know how to cancel the previous code and start a new one. We don't know how many digits to put in for the code.
To change your code:
1. Remove the inner cover plate from the lock.
2. Locate the small round reset button near the left side of the circuit board (Red or Black).
3. To program, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. This signals that your code has been accepted.
4. To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
hope this helps
John
Sep 16, 2011 | Weiser Lock Powerbolt 1000 Lock
How to key in code
This link will take you to the installation & programming instructions (on page 6) for the Kwikset Powerbolt, which is exactly the same as the Weiser Powerbolt:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
Jul 31, 2011 | Weiser Lock GED1460X GED1460X15A Antique...
How do I clear (erase) all codes from my Weiser Powerbolt 1000 in order to start with fresh entries? Adding new codes does NOT override/delete old existing codes as page 7 of my manual indicates. I now...
Jul 26, 2011 | Weiser Lock Powerbolt 1000 Lock
I need to reset the code
Jun 22, 2011 | Weiser Lock GED1460X3BR Lifetime Polished...
How do you reset all the codes on a weiser lock?
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Oct 29, 2010 | Weiser Lock Powerbolt 1000 Lock
How do i program 2 differt codes and erase old codes
Oct 26, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
How do you cancel existing codes?
The codes should be overwritten when you program in a new code.
Aug 09, 2010 | Weiser Lock Powerbolt 1000 Lock
Our Powerbolt 1000 will not delete old codes.
Are you certain you're programming new codes properly? It should just overwrite the codes when new ones are programmed. If you are doing it right, then I'd say you may want to have the unit repaired/replaced...
To program new codes (just in case):
Push the program button on the control board once for memory 1 OR twice for memory 2. Enter a 4-8 digit code. Push the lock button to end the entry. The unit will emit a 2-second long beep if your code is accepted. (If it doesn't beep, you were too slow. Try again.) Repeat the process for the other memory position.
Jan 30, 2010 | Weiser Lock Powerbolt 1000 Lock
After changing the code, it will not delete the old ones. how do you do that?
Be sure to change both codes. Press "program", then the code, then the lock button. Then press "program" twice, then a second code, then the lock button.
Nov 30, 2009 | Weiser Lock Powerbolt 1000 Lock
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
1,206 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
