Canon MVX250I Mini DV Digital Camcorder Logo
Anonymous Posted on Jul 09, 2012
Canon MVX250i zoom problem
Camera stuck in zoom mode on record and playback. I dropped the camera some years ago - sent it off for repair but the problem returned. I have a partial solution for recovering old tapes to a PC but I need a full solution really.
3 Related Answers
Anonymous
  • 1894 Answers
  • Posted on Jan 26, 2008
SOURCE: Color registration
does that appear in all kinds f tapes
A
Anonymous
  • Posted on Mar 07, 2008
SOURCE: Color registration on Canon GL2: purple recorded as blue
I have the same problem on my Canon XH-A1 and sony TRV33. I wonder if this problem applies to all camcorders?
Al Rush
  • 270 Answers
  • Posted on Mar 01, 2011
SOURCE: On playback of recorded tapes recently noticed
Sounds like dirty heads.
A clean and adjust of the tape path will most likely sort it out.
What if suddenly i dropped my canon mini dv md140 . still can play in playback mode. but when i turn to camera . try to recording . the screen just blank . im afraid if the lens o any glassy thing b
Your camera is really damaged. For repair, the best thing is to contact a certified Canon repair centre. They can tell you if it can be repaired and how much this could cost. Then you can decide what to do, repair, or save for a new camera.
3answers
Canon MVX250i Zoom
found the solution somewhere else on the net: just leave the camera lying with the batterie taken out for a while and it works again
2answers
Zoom goes into automatic pilot
Try take battery off camera while operating recording mode, amd put it back without turning off camera. I really do not know why this happend, but this solved my Canon mvx330i "by it self zooming" problem. try turn on digital zoom in meny and take of battery...
Camera will not power up correctly
Again the same old compact camera zoom lens problems - sand in lens, stuck AF motor, chewed up plastic gears...you only have to look at them wrong and they will die... (A very cynical camera repairer that has tried to repair these damn things soo often!!) Even cameras with internal lenses like the old Nikon 950/990/4500 still have troubles with stuck motors and broken lens parts. I despair - these things are just made to last the guarantee out (if that long) and die horribly afterwards!!
Image looks with white verital striped lines in playback mode
Mine had the same problem (except the stripes are horizontal).  I sent it to Canon and sure enough it is the CCD problem that many of these have.  The good news is that it is covered under a recall and Canon will fix it free, including the shipping.
After 2 years, erratic behavior.
Lens unit problem. Either imact or sand etc in the lens zooming gearbox area. Maybe uneconomical to repair on this model if new lens unit has to be installed. ( it is shutting off because the lens does not come on line properly and so the shutter and CCD do not come on line... when this happens camera switches off. )
17helpful
2answers
Canon MVX250i Zoom Problem
I had this problem on this camera. I found the battery removal rechnique seemed to work for only a short while, then the problem would come back repeatedly. I looked into just buying a new one but when I explained the problem to a salesman in an independent camera shop, he asked me if I'd just tried hitting the top of the camera. Apparently the motor sometimes gets stuck. Since the camera was virtually useless I tried this (hit it 2 or 3 times quite firmly, near the lens and by the accessory shoe). Now it zooms in and out perfectly and so far hasn't reverted to its problem state.
Must try to give the camera shop some other business - maybe when I buy a new stills camera
IXUS 700 zoom problem
contact customer support If has been dropped a repair price maybe well on the way to replacing the camera
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
