Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Began with opening ending with a loud "pop", then door would go limp, until i pushed button on remote and track would return to arm and finish the closing. Then in my return, I would push the open button, the door would lift, almost completely, then "pop" and go limp. Now the control track only makes a loud grinding noise.
Remove the cover from the motor housing and check the drive gear.
Posted on Jul 09, 2012
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
SOURCE: I have a chamberlin garage door opener that opens only a little
You probably have a broken spring on the door.
Posted on Jan 26, 2009
SOURCE: Genie Directlift garage door opener, wall control problem.
Sounds like a skinned wire on your front or rear limit switches is touching metal. Go over your low voltage wiring and test again.
Posted on Jul 05, 2009
SOURCE: garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Posted on Aug 04, 2009
SOURCE: Hi, I have a Lynx 455
Check the sensors in the doorway. Sounds like they may be misaligned. They need to be pointing at one another to work properly.
Posted on Sep 28, 2010
Feb 16, 2015 | Building Materials
Jun 21, 2012 | Home Security
Jan 03, 2012 | 2004 Nissan Maxima
Oct 05, 2011 | Sears Craftsman LiftMaster Chamberlain...
Feb 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
Nov 04, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Jun 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Nov 25, 2009 | liftmaster Chamberlain Garage Door Opener...
Feb 24, 2009 | Samsung CLP 300 Laser Printer
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
1,977 people viewed this question
It's weird that your door would make a popping sound and then go limp before making a grinding noise. Mine is making a loud screeching sound whenever it opens and closes, and it gets louder when it's colder. Our problems probably aren't related, but we might both benefit from having garage door repairs done. http://www.iansgaragedoor.com.au/door-re...
